For peak protection, trust Defender Series for MagSafe, our toughest case yet. It features a tri-layer design with a silicone outer cover, rigid inner shell and memory foam backing that work together to deflect whatever damage might come your way — and deliver 7X military standard drop defense. Plus, it's equipped with corners that absorb shock, all-over texturing for greater grip, integrated MagSafe magnets and built-in anchors for connecting phone straps. When you need real defenses, you need Defender Series for MagSafe.
Durable Protection
The OtterBox Defender Series offers protection with its three-layer design, keeping your cell phone safe from drops, bumps, and dust. -
Functional Design
This case is designed with built-in magnets that allow easy attachment while maintaining functionality and a grippy texture for secure handling. -
Eco-Friendly Materials
Constructed from 45% recycled plastic, this case demonstrates a commitment to sustainability while providing robust protection. -
Accessory Compatibility
With wireless charging support, this case enables hassle-free power access without removing the cover, ensuring convenience on-the-go. -
Added Features
Includes elements such as port covers and a memory foam lining that enhances protection and comfort during use.
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
J59G 051181 Condition: Customer return - item has been used and shows signs of use |
£5.89 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
