OtterBox Defender Series for Samsung Galaxy S8 - Black
Quicklinx: D1BCWS00 Mfr#: 77-54515
Stock Status: In Stock, Used Stock
24 in stock
£20.39 ex VAT
£24.46 inc VAT
Screenless design complements your curved screen. Take on your next big thing with confidence when you equip your phone with Defender, the rugged Galaxy S8 case designed for a perfect fit with Alpha Glass.
  • Drop protection
    Heavy-duty Galaxy S8 case deflects and absorbs impact, keeping it away from your device.
  • Dust protection
    Port covers block dust, dirt and lint from clogging up your jacks and ports.
  • Belt clip/holster
    Clip attaches to bags, belts and straps and locks in place for a hands-free viewing stand.
  • Multi-layer protection
    Solid polycarbonate shell and specialized rubber slipcover work together to protect your Galaxy S8 against accidental damage and wear and tear.
OtterBox Defender Series - back cover for mobile phone
Back cover for mobile phone
8.9 cm x 3.3 cm x 16.5 cm
117 g
Material
Polycarbonate, synthetic rubber
1-year warranty
Samsung Galaxy S8
8.9 cm
3.3 cm
16.5 cm
117 g
Rugged
Material
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Dust-resistant, scratch-resistant, dirt-resistant, drop-proof, tear-resistant, wear-resistant
Cover Type
Back cover
Belt clip holster
Cover Features
Stand function
1 year
Samsung Galaxy S8
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: D1BC 040814
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £2.68
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: OtterBox
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
