The multi-layered Defender Series iPhone 5/5S case guards against drops, shocks and dust while maintaining seamless usability. The high-impact polycarbonate shell fully covers the iPhone 5/5S while the integrated screen protector guards against scratches and smudges. Built-in memory foam cushions the device inside the case while the outer slipcover absorbs impact from drops and shocks. The included holster clips to nearly anything and doubles as a kickstand for hands-free use. Get protection that inspires confidence with the Defender Series iPhone 5/5S case from OtterBox.
What do 24+ tests and 238+ hours of testing mean to you? They mean your OtterBox case is ready to dive into your day without a second thought — just like you are. OtterBox Certified Drop+ Protection means drops, bumps and fumbles are just the beginning. It means your device is protected from the barrage of wear & tear you subject it to everyday. So go ahead — do what you do and leave the protection to us.
- Two-piece internal shell snaps around the iPhone while internal foam padding provides cushioning
- Integrated screen protector guards against scratches and smudges without affecting the sensitivity of the touch screen
- Outer synthetic rubber slipcover wraps around the inner shell and absorbs impact from drops and bumps
- Included holster swivels in any direction, clips easily to belts and bags and locks in place to act as a kickstand
Enhanced durability
The OtterBox Defender Series for the Apple iPhone 5s features a synthetic rubber material that provides a sturdy grip while ensuring the phone is protected from drops and bumps. The rugged design is complemented by foam padding that absorbs shock, offering an extra layer of security. -
Comprehensive protection
Equipped with a built-in screen protector, port covers, and a protective cover, this case shields your device from dust, scratches, and accidental drops. Its comprehensive design ensures that every aspect of your phone is safeguarded against daily wear and tear. -
Optimal functionality
Despite its robust protection, the OtterBox Defender Series maintains the phone's functionality. The precise cutouts and port covers provide easy access to all features without compromising on protection, ensuring that your device remains fully operational at all times.
- OtterBox Defender Series Apple iPhone 5s - protective cover for mobile phone
- Product Type
- Protective cover for mobile phone
- Material
- High-impact polycarbonate, synthetic rubber
- Black/black
- 1-year warranty
- Designed For
- Apple iPhone 5, 5s, SE
- Material
- Black/black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Dust-resistant, scratch-resistant, drop-proof
- Included Accessories
- Holster
- Foam padding, rugged, port covers, built-in screen protector
- 1 year
- Designed For
