Put three layers of rugged protection between your tablet and the world. This case is made to protect from heavy use, drops and tumbles.
What do 24+ tests and 238+ hours of testing mean to you? They mean your OtterBox case is ready to dive into your day without a second thought — just like you are. OtterBox Certified Drop+ Protection means drops, bumps and fumbles are just the beginning. It means your device is protected from the barrage of wear & tear you subject it to everyday. So go ahead — do what you do and leave the protection to us.
- Multi-layer iPad Pro case for maximum protection
- Screen protector guards touchscreen against scratches and scrapes
- Port plugs lock out dust and dirt
- Included shield stand comes equipped with a convenient slot for your Apple Pencil
- Apple Pencil and iPad not included – case only
- Does not work with Apple Smart Keyboard or Apple Smart Cover
Rugged defense
Defends your device from impact with shock-absorbing layers. -
Display protection
Built-in screen protector keeps out dust. -
360° coverage
Three layers surround your tablet with ultimate protection.
- OtterBox Defender Series - protective case for tablet
- Product Type
- Protective case for tablet
- Screen Size Compatibility
- 9.7"
- Material
- Polyurethane, polycarbonate, foam, synthetic rubber
- Black
- Rugged
- Material
- Black
Carrying Case
- Protective case
- Recommended Use
- For tablet
- 9.7"
- Protection
- Shockproof, dust-resistant, scratch-resistant, dirt-resistant, impact protection, drop-proof
- Included Accessories
- Shield stand
OtterBox Defender Series for Apple iPad Air Pro 9.7" - Black
