From original concept to final design, the Defender Series case was developed to create the most usable and protective solution possible. Developed with your active lifestyle in mind, the case employs multi-layer technology built with high-quality materials to create a rock-solid protective solution. The rugged silicone outer-layer absorbs the impact from bumps and shocks while the textured exterior provides enhanced grip. The built-in screen protector prevents scratches, smudges and fingerprints from getting on your high-resolution screen. The integrated shield stand acts as a protective cover on the front or the back and doubles as a stand for typing or viewing.
- OtterBox Defender Series Apple iPad 2/3 - case for tablet
- Product Type
- Case for tablet
- 19.664 cm x 1.836 cm x 25.147 cm
- 449.06 g
- Material
- Silicone, polycarbonate
- Black
- 1-year warranty
- 19.664 cm
- 1.836 cm
- 25.147 cm
- 449.06 g
- Material
- Black
Carrying Case
- Case
- Recommended Use
- For tablet
- Protection
- Dust-resistant, scratch-resistant
- Included Accessories
- Shield stand
- Foam padding, clear screen protector, camera lens cutout, power saving magnet, rugged, speaker cutout, port cut-outs
- 1 year
