Guard your tablet with Defender Series — the legendary protective Galaxy Tab A (2019, 10.1") Defender case. Designed for real life, its multi-layer construction, built-in screen protector and versatile shield stand provide ultra-durability for working hard and playing even harder.
Compatible With:
Inner hard shell, outer slipcover and shield stand deliver multi-layer defence
Built-in screen protector defends your display
Port covers prevent dirt, dust and lint from clogging jacks and ports
Hands-free shield stand works to keep your tablet upright
                Rugged protectionDesigned to withstand the rigors of daily use, the OtterBox Defender Series offers comprehensive protection against dirt, drops, and scratches. Its robust construction ensures your tablet remains safe from the everyday mishaps that can occur.
                Functional designFeaturing a belt clip for easy portability and a stand function for hands-free viewing, this protective cover combines utility with protection. The screenless edition allows for direct access to your device's screen while keeping it secure.
                Screen compatibilityTailored to fit a 10.1-inch screen, this protective cover ensures a perfect match for your tablet, providing edge-to-edge protection without compromising on functionality or screen accessibility.
- OtterBox Defender Series Screenless Edition - back cover for tablet
- Product Type
- Back cover for tablet
- Screen Size Compatibility
- 10.1"
- 16.08 cm x 1.5 cm x 25.5 cm
- 405 g
- Black
- Designed For
- Samsung Galaxy Tab A (2019) (10.1 in)
- 16.08 cm
- 1.5 cm
- 25.5 cm
- 405 g
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 10.1"
- Protection
- Scratch-resistant, dirt-resistant, drop-resistant
- Cover Type
- Back cover
- Carrying Strap
- Belt clip
- Cover Features
- Stand function
- Designed For
