Looking for legendary protection? You've found it with Defender Series. The multi-layer construction guards your device from serious drops, dirt, scrapes and bumps. Plus, the included holster does double duty as a belt clip or hands-free kickstand. Defender Series works hard and plays harder with a rugged and refined design that's ready for anything.
Robust protection
Designed with multi-layer construction and made from durable polycarbonate and synthetic rubber, this case offers solid protection against drops, bumps, and shocks. Its adherence to MIL-STD-810G 516.6 standards ensures your cell phone withstands daily use. -
Comprehensive coverage
Featuring port covers and raised edges, the OtterBox Defender Series case provides comprehensive protection. Port covers keep out dust and debris, while raised edges help protect the screen from scratches and cracks when placed face down. -
Wireless convenience
Despite its sturdy build, this case supports wireless charging, allowing you to charge your device without removing the case. This feature ensures your cell phone stays protected even while charging.
- OtterBox Defender Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 9.84 cm x 3.48 cm x 18.03 cm
- Material
- Polycarbonate, synthetic rubber
- Black
- Limited lifetime warranty
- Designed For
- Samsung Galaxy S22 Ultra
- 9.84 cm
- 3.48 cm
- 18.03 cm
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Drop+ protection, dirt protection, dust protection
- Cover Type
- Back cover
- Included Accessories
- Holster
- Multi-layer construction, port covers, wireless charging support, raised edges, 5G compatibility
- MIL-STD-810G 516.6
- Lifetime
- Designed For
