- Compatible with iPhone 15 Pro MAX (Only)
- Multi-layer durable phone cases are made with 50% recycled plastic
- DROP+ 4X as many drops as military standard (MIL-STD-810G 516.6) works with wireless and MagSafe charging pads (no magnets in case)
- Port covers block dust and dirt from jacks and ports and the included holster doubles as a kickstand
Robust protection
Experience peace of mind with the OtterBox Defender Series case, designed to offer comprehensive protection against drops, bumps, and scrapes. Its multi-layer construction, combining solid polycarbonate and synthetic rubber, ensures your cell phone withstands the rigors of daily use. -
Enhanced functionality
This case doesn't just protect; it enhances your phone's usability. With a belt clip / holster for easy access, raised lips to safeguard your screen and camera, and MagSafe compatibility for effortless wireless charging, it's the perfect blend of protection and convenience. -
Eco-conscious choice
Make a positive impact on the environment with the OtterBox Defender Series case. Crafted with 50% recycled plastic, this case not only protects your device but also supports sustainability, making it an ideal choice for eco-conscious consumers.
- OtterBox Defender Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 9.46 cm x 3.39 cm x 17.38 cm
- Material
- Polycarbonate, synthetic rubber
- Black
- Product Recycled Content
- 50 % - made of recycled plastic
- Limited lifetime warranty
- Designed For
- Apple iPhone 15 Pro Max
- 9.46 cm
- 3.39 cm
- 17.38 cm
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Anti-slip, dust protection, dirt protection, bump protection, drop+ protection, scrape protection, camera protection, impact-absorbent
- Cover Type
- Back cover
- Carrying Strap
- Belt clip / holster
- Wireless charging support, multi-layer construction, raised lips, 5G compatibility, solid inner shell
- MagSafe Compatibility
- Lifetime
- Designed For
