OtterBox Defender iPhone 15 Pro Max - Black
Quicklinx: HFMSWS00 Mfr#: 77-92550
  • Compatible with iPhone 15 Pro MAX (Only)
  • Multi-layer durable phone cases are made with 50% recycled plastic
  • DROP+ 4X as many drops as military standard (MIL-STD-810G 516.6) works with wireless and MagSafe charging pads (no magnets in case)
  • Port covers block dust and dirt from jacks and ports and the included holster doubles as a kickstand
  • Robust protection
    Experience peace of mind with the OtterBox Defender Series case, designed to offer comprehensive protection against drops, bumps, and scrapes. Its multi-layer construction, combining solid polycarbonate and synthetic rubber, ensures your cell phone withstands the rigors of daily use.
  • Enhanced functionality
    This case doesn't just protect; it enhances your phone's usability. With a belt clip / holster for easy access, raised lips to safeguard your screen and camera, and MagSafe compatibility for effortless wireless charging, it's the perfect blend of protection and convenience.
  • Eco-conscious choice
    Make a positive impact on the environment with the OtterBox Defender Series case. Crafted with 50% recycled plastic, this case not only protects your device but also supports sustainability, making it an ideal choice for eco-conscious consumers.
OtterBox Defender Series - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
9.46 cm x 3.39 cm x 17.38 cm
Material
Polycarbonate, synthetic rubber
Product Recycled Content
50 % - made of recycled plastic
Apple iPhone 15 Pro Max
9.46 cm
3.39 cm
17.38 cm
Material
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Anti-slip, dust protection, dirt protection, bump protection, drop+ protection, scrape protection, camera protection, impact-absorbent
Cover Type
Back cover
Carrying Strap
Belt clip / holster
Wireless charging support, multi-layer construction, raised lips, 5G compatibility, solid inner shell
MagSafe Compatibility
Lifetime
