Durable iPhone 15 Plus and iPhone 14 Plus case, Defender Series, with a multi-layer construction guards your device from serious drops, dirt, scrapes and bumps. Wireless ready, it works with both Qi charging and MagSafe (no magnets in case).
- Durable rubber outer cover provides drop-resistant grip
- Port covers block dust and dirt
- Bumpers around the camera protect against hard hits
- Screen lip keeps display hovering safely off surfaces
- Precious cutout for all function and port
Robust protection
Experience peace of mind with the OtterBox Defender Series case, designed to offer multi-layer construction that combines a solid inner shell with a synthetic rubber outer layer. This design ensures your cell phone withstands drops, bumps, and shocks, keeping it secure in demanding environments. -
Enhanced functionality
The case is not just about protection; it's also about convenience. With features like a belt clip / holster for easy access and wireless charging support, you can enjoy your device's functionality without compromise. The raised lips protect the screen and camera, ensuring they are safe from scratches and direct impacts. -
Eco-friendly choice
Make a positive impact on the environment with the OtterBox Defender Series case. Made of 50% recycled plastic, this case helps reduce waste and supports sustainability without sacrificing quality or protection.
- OtterBox Defender Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 9.649 cm x 3.301 cm x 17.208 cm
- Material
- Polycarbonate, synthetic rubber
- Black
- Product Recycled Content
- 50 % - made of recycled plastic
- Limited lifetime warranty
- Designed For
- Apple iPhone 14 Plus, 15 Plus
- 9.649 cm
- 3.301 cm
- 17.208 cm
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Anti-slip, dust protection, dirt protection, bump protection, drop+ protection, scrape protection, camera protection, impact-absorbent
- Cover Type
- Back cover
- Carrying Strap
- Belt clip / holster
- Wireless charging support, multi-layer construction, raised lips, 5G compatibility, solid inner shell
- MagSafe Compatibility
- Lifetime
- Designed For
