Looking for legendary protection? You've found it with the durable phone case, Defender Series. The multi-layer construction guards your device from serious drops, dirt, scrapes and bumps. Wireless ready, it works with both Qi charging and MagSafe. Plus, the included holster does double duty as a belt clip or hands-free kickstand. The Defender Series works hard and plays harder with a rugged and refined design that's ready for anything.
Rugged durability
Engineered with multi-layer construction and synthetic rubber, the OtterBox Defender Series case offers robust protection for your cell phone. Its design meets the rigorous MIL-STD-810G 516.6 standards, ensuring your device is safeguarded against bumps, drops, and rough handling. -
Enhanced functionality
Featuring a belt clip / holster and a stand function, this protective cover enhances your mobile experience. Whether you're on-the-go or enjoying media, your convenience is prioritized. -
Comprehensive protection
With DROP+ technology, port covers, and compatibility with wireless charging, this case doesn't just protect against physical damage. It also keeps out dirt and supports Qi wireless charging standards, allowing for easy power-ups without removing the case. -
Eco-conscious choice
Made of 50% recycled plastic, the OtterBox Defender Series case is a step towards sustainability. Choosing this case means opting for a product that reduces waste without compromising on protection or quality. -
MagSafe and 5G ready
Designed to accommodate technology, this case supports MagSafe accessories and 5G connectivity. Enjoy the benefits of faster wireless speeds and easy attachment of MagSafe accessories without sacrificing protection.
- OtterBox Defender Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 9.53 cm x 3.33 cm x 17.44 cm
- Material
- Polycarbonate, synthetic rubber
- Black
- Product Recycled Content
- 50 % - made of recycled plastic
- Limited lifetime warranty
- Designed For
- Apple iPhone 14 Pro Max
- 9.53 cm
- 3.33 cm
- 17.44 cm
- Package Details
- Polybag
- Rugged
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Dirt-resistant, bump protection, drop+ protection
- Wireless Charging Standards
- Qi
- Cover Type
- Back cover
- Carrying Strap
- Belt clip / holster
- Wireless charging support, DROP+ technology, multi-layer construction, 5G compatibility, port covers
- Cover Features
- Stand function
- MagSafe Compatibility
- MIL-STD-810G 516.6
- Lifetime
- Designed For
