- Compatible with iPhone 15 Pro (Only)
- DROP+ 3X as many drops as military standard (MIL -STD-810G 516.6) and is wireless charging compatible (no magnets in case)
- Dual-layer thin phone case is made with 35% recycled plastic and features a rigid outer shell to protect against everyday scrapes and scratches while an internal rubber cover absorbs impact
- Slim profile is designed to slip easily in and out of pockets, with textured sides for a secure grip
Eco-friendly choice
Crafted with 35% recycled plastic, this case not only protects your device but also contributes to a healthier planet. -
Robust protection
Featuring anti-slip, bump, drop, scrape, and scratch protection, this case is designed to shield your phone from everyday accidents. -
Wireless convenience
Supports Qi wireless charging standards, allowing for effortless charging without removing the case. -
Pocket-friendly design
The slim, pocket-friendly design ensures your phone stays portable without sacrificing protection. -
MagSafe compatible
Fully compatible with MagSafe accessories, offering a seamless experience with your device's ecosystem.
- OtterBox Commuter Series - back cover for mobile phone
- Product Type
- Back cover for mobile phone - MagSafe compatibility
- 7.82 cm x 1.48 cm x 15.31 cm
- Material
- Polycarbonate, synthetic rubber
- Black
- Product Recycled Content
- 35 % - made of recycled plastic
- Designed For
- Apple iPhone 15 Pro
- 7.82 cm
- 1.48 cm
- 15.31 cm
- Material
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Anti-slip, scratch protection, bump protection, drop+ protection, scrape protection
- Wireless Charging Standards
- Qi
- Cover Type
- Back cover
- Wireless charging support, port covers, pocket-friendly design
- MagSafe Compatibility
- Designed For
