OtterBox Commuter for iPhone 14 Pro Max - Black
Quicklinx: H0F9WS00 Mfr#: 77-88446
Product Range: OtterBox Commuter Series
Get moving with Commuter Series, the thin phone case that keeps your phone safe from drops and bumps. A silver-based antimicrobial additive is integrated into the case that helps inhibit microbial growth and defends the case exterior against many common bacteria. Wireless ready, it works with both Qi charging and MagSafe. Built to beat the daily grind, Commuter Series combines a pocket-friendly profile with robust defense and added grip to ensure you keep going mile after mile.
  • Robust protection
    Crafted from polycarbonate and synthetic rubber, this protective cover offers a rugged shield against bumps, drops, and everyday wear. Its design meets the rigorous MIL-STD-810G 516.6 standards, ensuring your cell phone withstands the challenges of daily use.
  • Antimicrobial technology
    Featuring an antimicrobial case, it actively inhibits the growth of bacteria on the phone's surface, promoting a cleaner, more hygienic experience during use.
  • Wireless convenience
    With Qi wireless charging standards compatibility, this case allows for effortless charging without the need for direct cable connections. Enjoy the convenience of wireless technology while keeping your device protected.
  • MagSafe compatible
    Designed to work seamlessly with MagSafe accessories, this case ensures you can utilize your favorite MagSafe products without sacrificing protection or functionality.
  • Comprehensive protection
    This case is engineered to be dirt-resistant, dust-resistant, and drop-resistant, offering comprehensive protection for your cell phone from the elements and accidental mishaps.
OtterBox Commuter Series - back cover for mobile phone
Back cover for mobile phone - MagSafe compatibility
16.72 cm x 8.52 cm x 1.48 cm
Material
Polycarbonate, synthetic rubber
Apple iPhone 14 Pro Max
16.72 cm
8.52 cm
1.48 cm
Rugged
Material
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Dust-resistant, dirt-resistant, drop-resistant, bump protection, drop+ protection
Wireless Charging Standards
Qi
Cover Type
Back cover
ProPack packaging
MagSafe Compatibility
MIL-STD-810G 516.6
Limited warranty - lifetime
Brand: OtterBox
