OtterBox Clearly Protected Case for Samsung Galaxy A5 (2017) - Clear
Quicklinx: CTSHWS00 Mfr#: 77-55318
33 in stock
£11.65 ex VAT
£13.98 inc VAT
Keep your phone like new with lightweight, virtually invisible scratch and bump resistance. Clearly Protected Case, the ultra-thin case from OtterBox wraps your phone with a precision fit.
What do 24+ tests and 238+ hours of testing mean to you? They mean your OtterBox case is ready to dive into your day without a second thought — just like you are. OtterBox Certified Drop+ Protection means drops, bumps and fumbles are just the beginning. It means your device is protected from the barrage of wear & tear you subject it to everyday. So go ahead — do what you do and leave the protection to us.
  • Transparent case: clear layer shows off your phone’s sleek design
  • Ultra-thin: lightweight, virtually invisible case
  • UV-resistant: transparent material won’t yellow or tarnish over time
  • Precision fit: one-piece design wraps around your phone for a tight fit
  • Screen bumper: raised, beveled edge buffers touchscreen
  • Clear case
    Clear layer shows off your phone's sleek design.
  • Ultra-slim profile
    Lightweight, virtually invisible case complements the sleek, lean lines of your phone.
  • Scratch protection
    Helps preserve your phone's pristine condition while you're out and about.
OtterBox Clearly Protected Case - back cover for mobile phone
Back cover for mobile phone
Material
Thermoplastic polyurethane (TPU)
Clear
Material
Clear
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Drop-proof
Cover Type
Back cover
2 years
Brand: OtterBox
Price Range Ex VAT: 0 - 50
