Project bright vibrant widescreen presentations any time of day. Designed for meeting rooms and classrooms, the X402 boasts a long lamp life and energy-saving features which provide a low overall cost of ownership.
This projector has a built-in speaker, networking capabilites, Full 3D technology and can be easily connected via a HDMI cable, giving a clear projected image with sound. The lightweight projector can be installed or taken on the move in the handy carry bag for off-site meetings.
High contrast
Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications. -
Full 3D
Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the latest generation games consoles. Support for 144 Hz rapid refresh rate provides ultra-smooth flicker free images. -
Integrated speaker
The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers -
Eco+
Eco+ technology brings together high contrast, improved lamp life and energy saving features that are easy to use while reducing power consumption. -
Energy saving
Using the specially designed lamp modes, you can reduce the power consumption by up to 70%. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance. -
Auto power off
There may be instances when the projector is left running when not in use. To help save energy, the "auto power off" feature automatically turns off the projector after a set period of time if it is not being used. -
Eco AV mute
Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption by up to 70%, further prolonging the life of your lamp. -
Long lamp life
Reduce the number of lamp changes with lamp life of long hours. -
Remote mouse and laser
Keep your audience's attention focused on the right things using the simple, yet powerful remote with USB mouse control and built in laser pointer. -
Networking and control
Featuring a wide range of options you can control and monitor the projector remotely. -
Amazing colors
For vibrant, natural looking images, Optoma projectors incorporate BrilliantColor multi-color processing technology. -
Quick resume
This feature allows the projector to be instantly powered on again, if it is accidentally switched off.
- Optoma X402 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Stereo speakers
- Microdisplay
- DarkChip 3
- Brightness
- 4200 ANSI lumens
- Contrast Ratio
- 20000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 260 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 306 Watt
- 31.46 cm x 22.36 cm x 10.17 cm
- 2.57 kg
- 3-year warranty
- DLP projector
- 3D Capable
- Built-in Devices
- Stereo speakers
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 4200 ANSI lumens
- Contrast Ratio
- 20000:1
- Image Size
- 92 cm - 769 cm
- Projection Distance
- 1.2 m - 12 m
- Throw Ratio
- 1.6 - 1.92:1
- Uniformity
- 80 %
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 91.1 kHz
- Bulb type
- 260 Watt
- Bulb life cycle
- Controls & Adjustments
- Volume, brightness, keystone correction, zoom
- OSD Languages
- Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian
- BrilliantColor, 16:9 aspect ratio support, DarkChip3 single-chip DLP technology, PJlink, Crestron RoomView, AMX Device Discovery, Auto Power Off, Eco+ technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.4-2.66
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-in / microphone input - mini-phone 3.5 mm , 1 x USB - 4 pin USB Type B
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), security bar
- Security Slot Type
- Kensington security slot
- RoHS
- Power Source
- AC
- Voltage Required
- 306 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.46 cm
- 22.36 cm
- 10.17 cm
- 2.57 kg
- Limited warranty - 3 years
- 5 °C
- 40 °C
- Sound Emission (Economic Mode)
- 31 dB
