Optoma White Flush Universal Mount
Quicklinx: 8RWTWS00 Mfr#: OCM818W-RU
Accessory Type: Mount
£58.33 ex VAT
£69.99 inc VAT
The OCM818W-RU white universal projector flush mount is suitable for installation in the office or at home. Easy to set up with its unique low-profile design gives you everything you need for quick adjustment, the flexibility to fit almost any projector and hassle free projector maintenance. It's the perfect universal projector flush mount.
  • Universal projector mount
    Compatible with multiple projectors.
  • Easy setup
    Install and adjust with no fuss.
  • Connection
    Quickly connect and disconnect your projector.
  • Super-strong
    Supports up to 15 kg.
Optoma OCM818W-RU mounting kit - for projector - white
Mounting kit - ceiling mountable
Mounting Components
Flush ceiling mount
16.1 cm x 10 cm x 12.1 cm
Adjustments
Roll, pitch
1.2 kg
Recommended Use
Projector
Max Load Weight
15 kg
White
1-year warranty
Optoma DH351, DS322, DW322, DX322, EH416, ES556, EW1691, EW556, EW631, EX555, EX556, EX631, FX5200, GT760, H117, H185, H190, HD145, HD28, HD6720, HZ40, HZ48, S336, S371, S381, S400, UHD35, UHD38, UHZ50, UHZ65, W303, W309, W371, W381, W400, X340, X381, X400, ZU500, ZU720, ZW400; ThemeScene HD23
16.1 cm
10 cm
12.1 cm
1.2 kg
White
AV Furniture
Mounting kit
Mounting Components
Flush ceiling mount
Recommended Use
Projector
Placing / Mounting
Ceiling mountable
Adjustments
Roll, pitch
Max Load Weight
15 kg
Rotating, horizontal shift
Limited warranty - 1 year
Optoma DH1010, DH1015, DH351, DH7-XL, DS211, DS322e, DS327, DS329, DS5-XL, DW318, DW322, DX211, DX322, DX327, DX329, EH1020, EH416e, ES521, ES550, ES551, ES556, EW1691e, EW531, EW536, EW556, EW615, EW631, EW762, EW766, EW766W, EW775, EX521, EX536, EX538, EX550, EX551, EX555, EX556, EX612, EX615, EX631, EX7155e, EX762, EX765, EX765W, EX784, EX785, FW5200, FW5200 Eco+, FX5200, GT750, GT750-XL, GT760A, H117ST, H185X, H190X, Hd100X, HD145X, HD20, HD200X, HD20-LV, HD23, HD230X, HD28B, HD300X, HD33, HD3300, HD600X-LV, HD6720, HD67N, HD8300, HD87, HZ40STx, HZ48UST, S336, S371, S381, S400, S400LVe, UHD35, UHD35x, UHD38, UHZ50, UHZ65LV, W303ST, W309ST, W371, W381, W400LVe, X340UST, X381, X400LV, X400LVe, ZU500USTE, ZU720TST, ZW400 , Optoma GameTime GT750, GT750E , Optoma Home Theater Series HD20, HD200X, HD20LV , Optoma ProScene EH2060 , Optoma ThemeScene HD23, HD230X, HD33, HD83, HD87
Brand: Optoma
