Ideally partnered with a widescreen notebook, HD sources or a mobile device, the W304M delivers bright vivid presentations and videos in the office or on the road.
This travel-friendly projector incorporates a staggering 3100 ANSI lumens allowing you to project bright, crystal clear presentations during the day, leaving your audience speechless every time the projector is turned on.
Being small doesn't mean that you miss out on specification though, the W304M incorporates a built in speaker, HDMI connectivity, Full 3D technology and wireless capabilities allowing you to project wirelessly from a laptop or mobile device. It also comes with a convenient carry bag for easy transportation.
Projecting with laptops, Macs or even tablets has never been so easy.
Ultra portable
The W304M is ultra light and ultra portable, coupled with the included carry case make it ideal for presentations on the go. -
Brightness where it matters
Room lighting can be unpredictable for the business traveler; you never know what to expect. The W304M has a powerful lamp producing 3100 ANSI lumens, so you can be sure your presentation will be bright and clear. -
Rapid shut down
Pack up your projector and go after 10 seconds from pressing the power button with rapid shutdown, saving you both time and money. -
True WXGA resolution
The W304M is the perfect companion for widescreen laptops. Your presentations will appear as sharp and detailed as they do on your widescreen laptop in WXGA (1280 x 800) resolution. WXGA resolution gives 30% more pixels than XGA. -
Amazing colors
The W304M incorporates BrilliantColor technology to produce stunningly bright images with perfectly balanced life-like colors. -
Clear, focused images
Be sure to have your audience's attention during a presentation with a stunning 10000:1 contrast ratio for pin sharp graphics and crystal clear text. Crisper whites and ultra-rich make images come alive and text easier to read - ideal for business and education presentations and the occasional movie. -
Full 3D ready
Using the inherent speed of DLP technology, The Optoma W304M, full 3D projector can display true 3D content form any 3D display device, such as 3D Blu-ray, PS3, Xbox and Sky3D. -
Environmentally friendly
The X304M incorporates energy saving features to conserve power and extend the lamp life up to 5000 hours. This includes Eco mode, for reduced power consumption during operation, a sleep timer which when activated will automatically switch off the projector if it is accidentally left on when no longer required and a less then 0.5 W standby mode which will ensure the minimum energy consumption when the projector is not being used.
- Optoma W304M - DLP projector - portable - 3D
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Black
- Built-in Devices
- Speaker
- Brightness
- 3100 ANSI lumens
- Contrast Ratio
- 10000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- SHP 220 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 280 Watt
- 22 cm x 17.8 cm x 7.1 cm
- 1.5 kg
- 2 years warranty
- 3D Capable
- Built-in Devices
- Speaker
- Enclosure Colour
- Black
Projector
- Brightness
- 3100 ANSI lumens
- Contrast Ratio
- 10000:1
- Image Size
- 79 cm - 943 cm
- Projection Distance
- 1.2 m - 12 m
- Uniformity
- 80 %
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91.4 kHz
- Bulb type
- SHP 220 Watt
- Bulb life cycle
- Controls & Adjustments
- Mute, input select, keystone correction
- LED Indicators, DLP Link
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.15x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- 1 x HDMI - 19 pin HDMI Type A , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x composite video input - RCA , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), keypad lock
- Security Slot Type
- Kensington security slot
- Nominal Voltage
- 280 Watt
- Power Consumption Stand by
- 0.5 Watt
- 22 cm
- 17.8 cm
- 7.1 cm
- 1.5 kg
- Limited warranty - 2 years , Limited warranty - lamp - 1 year
- 5 °C
- 45 °C
- 0 - 85%
- Sound Emission (Economic Mode)
- 32 dB
