Optoma Universal Projector Ceiling Pole Mount
Quicklinx: 8BL4WS00 Mfr#: OCM815B
Type: [N/A]
Brightness: [N/A]
Contrast Ratio: [N/A]
Portability: [N/A]
Resolution: [N/A]
£57.36 ex VAT
£68.83 inc VAT
The OCM815B universal projector pole mount is ideal for high ceilings. Easy to set up with its unique design gives you everything you need for quick adjustment, the flexibility to fit almost any projector and hassle free projector maintenance. It's the perfect universal projector pole mount.
Optoma OCM815B mounting kit - for projector - black
Mounting kit - ceiling mountable
Mounting Components
Pole mount
Adjustable Height
57.5-82.5 cm
Adjustments
Pitch
Recommended Use
Projector
Max Load Weight
15 kg
Optoma DH351, DS320, DS322e, DZ500, EH416e, H117ST, H185X, H190X, HD145X, HD28B, HZ40ST, HZ40STx, HZ48UST, S336, S371, S381, S400, S400LVe, UHD35x, UHZ50, W309ST, W371, W381, W400LVe, X340UST, X381, X400LV, X400LVe, ZU500USTE, ZU720TST, ZW400
Adjustable Height
57.5-82.5 cm
AV Furniture
Mounting kit
Mounting Components
Pole mount
Recommended Use
Projector
Placing / Mounting
Ceiling mountable
Cable Management
Integrated cable management
Adjustments
Pitch
Max Load Weight
15 kg
Adjustable height, rotating
Type: [N/A]
Brightness: [N/A]
Portability: [N/A]
Resolution: [N/A]
Brand: Optoma
