Optoma S321 SVGA 800 x 600 3200 Lumens 3D Projector
Quicklinx: C3YHWS00 Mfr#: 95.71P01GC0E
Project bright vibrant presentations effortlessly any time on day. Designed for meeting rooms and classrooms, the S321 boasts sRGB accurate true to life color reproduction, long lamp life and energy-saving features to provide you with a low overall cost of ownership. This projector can be easily connected to a PC or laptop to give you a clear projected image. Portable and lightweight projector can be installed or taken on the move for off-site meetings.
  • Amazing colors
    For vibrant, natural looking images, Optoma projectors incorporate BrilliantColor multi-color processing technology. This projector also conforms to sRGB standard to produce realistic true to life colors possible.
  • Eco+
    Eco+ technology brings together high contrast, improved lamp life and energy saving features that are easy to use while reducing power consumption.
  • Energy saving
    Using the specially designed lamp modes, you can reduce the power consumption. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance.
  • High contrast
    Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
  • 3D ready
    Optoma 3D ready projectors can output video and images at an astonishing rate of 120 Hz, allowing you to show full screen, full color, stereoscopic 3D; perfect for business and education applications.
  • Eco AV mute
    Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption, further prolonging the life of your lamp.
  • Quick resume
    This feature allows the projector to be instantly powered on again, if it is accidentally switched off.
  • Auto power off
    There may be instances when the projector is left running when not in use. To help save energy, the "Auto Power Off" feature automatically turns off the projector after a set period of time if it is not being used.
Optoma S321 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DarkChip 3
Brightness
3200 lumens
Contrast Ratio
22000:1
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
195 watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video (NTSC, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
187 watt
29.8 cm x 23 cm x 9.65 cm
2.17 kg
DLP projector
3D Capable
Projector
Microdisplay
DarkChip 3
Brightness
3200 lumens
Contrast Ratio
22000:1
Image Size
71 cm - 773 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.94 - 2.16:1
Uniformity
75 %
Resolution
SVGA - SVGA (800 x 600) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 91.1 kHz
Bulb type
195 watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Romanian, Japanese, Korean
BrilliantColor, DLP 3D Ready, 16:9 aspect ratio support, DarkChip3 single-chip DLP technology, Eco+ technology, ProJect Green
Lens
Focus Type
Manual
Lens Aperture
F/2.4-2.53
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video
Video Modes
1 x USB - mini-USB Type B , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
187 watt
Power Consumption Stand by
0.5 watt
29.8 cm
23 cm
9.65 cm
2.17 kg
5 °C
0 - 85%
Sound Emission
29 dB
