Optoma Replacement Lamp for EX521 ES521 DX211 DS211
Quicklinx: 8NVCWS00 Mfr#: SP.8LG01GC01
Lamp modules supplied by Optoma are designed and tested to work specifically with your Optoma projector. Whilst copy lamp modules may carry original manufacturer's bulbs, Optoma specifically screens all its lamp modules to ensure the highest quality and longevity.
  • Enhanced brightness
    The Optoma E20.8 elliptical projector lamp is designed to deliver an impressive 180 W of power, ensuring your presentations and media are seen in clear light. With such a robust capacity, it enhances the brightness of your projector, making it suitable for both professional and home environments where clarity is important.
  • Seamless compatibility
    Specifically engineered for compatibility with PC systems, this projector lamp integrates smoothly with your existing setup. Its precise design by Optoma ensures a perfect fit and optimal performance for your OSRAM series projectors.
OSRAM E20.8 ellpitical - projector lamp
Projector lamp - 180 Watt
Optoma DS211, DX211, ES521, EX521
Projector lamp
Lamp
180 Watt
