Optoma Replacement lamp for EH1060i; EX779i
Quicklinx: C02GWS00 Mfr#: DE.5811116885-SOT
The Optoma E20.9 projector lamp is a vital accessory for enhancing your projection quality, offering a significant upgrade or replacement for your current setup. With a powerful 280 W capacity, it ensures that your presentations and videos are projected with clarity and brightness, making it ideal for both professional and educational environments. Its design is tailored for PC compatibility, allowing for a smooth and efficient integration into your existing system. Whether you're in a classroom or a boardroom, the Optoma E20.9 projector lamp is designed to meet your projection needs with reliability and performance.
  • Enhanced brightness
    The Optoma E20.9 projector lamp, with its 280 W capacity, ensures your presentations are vivid and brightly illuminated, enhancing visibility in any room setting.
  • Seamless compatibility
    Designed specifically for PC compatibility, this projector lamp integrates smoothly with your existing setup, offering a hassle-free upgrade or replacement solution.
OSRAM E20.9 - projector lamp
Projector lamp - 280 Watt
Optoma EH1060i, EX779i
Projector lamp
Lamp
280 Watt
