Optoma Panoview DS3120PMG Manual Pull Down Projection Screen 120"
Quicklinx: 71ZKWS00 Mfr#: DS3120PMG+
Accessory Type: Projection screen
£242.90 ex VAT
£291.48 inc VAT
Panoview offer a wide selection of quality front projection screens suitable for any situation, from small meeting to large conference rooms and great for home cinema applications.
This Panoview screens is built to a high standard and are rigorously checked and tested throughout the production process to ensure the highest possible build quality and finish.
  • Controlled screen return
    Panoview PMG+ Manual Screens feature speed reduction-retraction. Simply pull down lightly to release the locking mechanism, let go and the screen will slowly return to the casing.
  • Selflock
    Pull down the screen and hold for 3 seconds, then release. The screen will stay at the desired position.
Optoma Panoview Pull Down Manual DS-3120PMG+ - projection screen - 120" (305 cm)
Projection screen
Placing / Mounting
Ceiling mountable, wall mountable
Projection Screen Image Diagonal Size
120" (305 cm)
Projection Image Size
266 cm x 149 cm
Aspect Ratio
4:3
Screen Surface
Matte White
285 cm x 7.8 cm x 7.9 cm
14.1 kg
Projection screen
Placing / Mounting
Image Diagonal Size
120" (305 cm)
Image Width
266 cm
Image Height
149 cm
Screen Surface
Matte White
Aspect Ratio
4:3
Gain
1.0x
Black borders
285 cm - 7.8 cm - 7.9 cm
14.1 kg
Water-resistant, fire resistant
Brand: Optoma
