Optoma Panoview DS-3100PMG Manual Pull Down Projection Screen 4:3 100"
Quicklinx: 71ZHWS00 Mfr#: DS-3100PMG+
Accessory Type: Projection screen
£194.58 ex VAT
£233.49 inc VAT
The metal casing is compact and elegant. The white cover is coated with PVC technology that enhances the feel and esthetics.
The matte white material provides different brightness and viewing ranges, flexible to suit every setting. The matted white allows a wider view range and soft colors.
It is suited for various venues such as education facilities, home theaters, boardrooms, or other entertainment sites.
  • Trendy and elegant
  • Resolution
  • Location
Optoma Panoview Pull Down Manual DS-3100PMG+ - projection screen - 100" (254 cm)
Projection screen
Placing / Mounting
Ceiling mountable, wall mountable
Projection Screen Image Diagonal Size
100" (254 cm)
Projection Image Size
203 cm x 152 cm
Aspect Ratio
4:3
Screen Surface
Matte White
223 cm
11.6 kg
Projection screen
Placing / Mounting
Image Diagonal Size
100" (254 cm)
Image Width
203 cm
Image Height
152 cm
Screen Surface
Matte White
Aspect Ratio
4:3
Gain
1.0x
Border Size
5 cm
Black borders
223 cm
11.6 kg
Mounting Kit
Included
Brand: Optoma
