The HD200X home cinema projector delivers the kind of picture quality associated with the best digital cinema performance around the world. With a digital HDMI signal you can create a true digital projection system that produces a spectacular Full HD cinematic experience in your own home. A masterly collaboration of Full HD DLP technology from Texas instruments and Optoma craftsmanship produces a stunningly bright image with perfectly balanced vivid color, crystal clarity and the exceptional light and shade detail only possible with a high ANSI contrast projector.
ANSI contrast
ANSI contrast is a way of measuring the true "real world" contrast performance you can expect from a projector in your own home. This measurement technique includes a reproducible procedure that can be used to compare the performance of projectors using different display technologies. With an ANSI contrast ratio significantly higher than many LCD based projectors, the HD2000X is the only choice for Home Cinema purists that expect ultimate image fidelity in their home. -
24P
Most movies are shot at 24 frames per second. To preserve the purity of the original image the HD200X can accept High Definition sources at 24 frames per second and so to display movies exactly as the director intended.
- Optoma HD200X - DLP projector - portable
- DLP projector - 1080p
- Brightness
- 1500 lumens
- Contrast Ratio
- 3500:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- 230 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i
- Power
- AC 120/230 V (50/60 Hz)
- 308 Watt
- 32.4 cm x 23.4 cm x 9.7 cm
- 2.9 kg
Projector
- Brightness
- 1500 lumens
- Contrast Ratio
- 3500:1
- Image Size
- 95 cm - 764 cm
- Projection Distance
- 1.5 m - 10 m
- Throw Ratio
- 1.5 - 1.8:1
- Resolution
- 16:9
- Colour Support
- Bulb type
- 230 Watt
- Bulb life cycle
Lens
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -5/ +5
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video
- Video Modes
Input Device
- External
- 2 x HDMI input - 19 pin HDMI Type A , 1 x component video input - RCA x 3 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA
- Included Accessories
- Wireless remote control
- Voltage Required
- 308 Watt
- Power Consumption Operational (Standby)
- 1 Watt
- 32.4 cm
- 23.4 cm
- 9.7 cm
- 2.9 kg
- 5 °C
- 35 °C
- 0 - 80%
- Sound Emission
- 34 dB
Optoma HD200X Full HD Home Cinema Projector
