Optoma GT1080 1080p Short-throw Projector
Quicklinx: C19CWS00 Mfr#: GT1080
Experience games and movies the way you have never seen before on an Optoma GT1080 high definition gaming projector.
Designed for serious gamers like you, the Optoma GT1080 delivers super-fast 2800 lumens bright HD games to the screen with stunning color accuracy and a 25,000:1 contrast ratio for maximum image detail and improved visibility. Allowing you to acquire and assess information easily and to formulate a faster, more accurate response to defeat your opponents.
Equipped with the level of all digital connectivity you need for today's gaming gear, the Optoma GT1080 will keep you on top with two HDMI ports, MHL connectivity, VESA 3D sync port, razor sharp 0.5:1 short throw lens to deliver larger than life images even in space constrained environments, powerful 10 W audio, 12 V output, whisper quiet operation and up to 6500-hour long lamp life for worry-free gaming.
Optoma GT1080 - DLP projector - short-throw - portable - 3D
DLP projector - 1080p
3D Capable
Yes (transmitter and 3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
2800 ANSI lumens
Contrast Ratio
25000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Lens
Short-throw fixed lens
Bulb type
190 Watt
Bulb life cycle
Up to 6500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
(PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
262 Watt
31.5 cm x 22.4 cm x 10.2 cm
2.7 kg
1-year warranty
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
2800 ANSI lumens
Contrast Ratio
25000:1 (dynamic)
Image Size
106 cm - 774 cm
Projection Distance
0.5 m - 3.35 m
Throw Ratio
0.50:1
Uniformity
80 %
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 91.146 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
BrilliantColor, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, MHL compliance
Lens
Lens Aperture
F/2.8
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Video Interfaces
HDMI, MHL
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x HDMI input - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x 3D Sync out - 3 PIN mini-DIN , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B (management)
Carrying case, lens cap strap, wireless remote control
1 x HDMI cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar, keypad lock
RoHS
Power Source
AC
262 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
31.5 cm
22.4 cm
10.2 cm
2.7 kg
Limited warranty - parts and labour - 1 year , Limited warranty - lamp - 90 days
5 °C
0 - 85%
26 dB
