Optoma EX7155e DLP XGA 3000 Lumens Projector
Quicklinx: 6M64WS00 Mfr#: EX7155E
  • High-Definition Multimedia Interface (HDMI)
Professional presentations on the move
-Small & lightweight - 1.4 kg
-XGA - 3000 Lumens
-Digital Connectivity - HDMI Input
-Internal Speaker
The EX7155e brings together amazing brightness, portability and cutting-edge design in one compact DLP® projector.
High brightness, 3000 ANSI Lumens; perfect for large rooms, yet it weighs just 1.4kg, making it more than light enough to be taken on the road. Small doesn't mean that you miss out on specification though, this projector still comes with an HDMI input for digital clarity, filter-free, low maintenance design and our unique Optoma colour and imager guarantees.
STAGGERING BRIGHTNESS
Use in brightly lit locations with the powerful 3000 ANSI Lumens to define the smallest screen details clearly. Your audience will experience the remarkable picture of the EX7155e in almost any lighting situation.
TRUE HDMI
Project crystal clear images using the latest HDMI v1.3 input. Hassle-free projection from a computer/DVD player with a single HDMI cable - no need for separate audio cables.
AMAZING COLOURS
The EX7155e incorporates BrilliantColor™ technology to produce stunningly bright images with perfectly balanced life-like colours.
  • Staggering brightness
    Use in brightly lit locations with the powerful 3000 ANSI lumens to define the smallest screen details clearly. Your audience will experience the remarkable picture of the EX7155e in almost any lighting situation.
  • True HDMI
  • Amazing colors
    The EX7155e incorporates BrilliantColor technology to produce stunningly bright images with perfectly balanced life-like colors.
  • Customized start up screen
    First impressions are important so set the company logo as your start up screen to make that lasting impression.
  • Environmentally friendly
    The EX7155e incorporates energy saving features to conserve power and extend the lamp life.
Optoma EX7155e - DLP projector - portable
DLP projector
Built-in Devices
Speaker
Brightness
3000 lumens
Contrast Ratio
2500:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
16.7 million colours
Bulb type
220 Watt
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Digital Video Standard
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
280 Watt
22 cm x 17.8 cm x 7.1 cm
1.4 kg
5-year warranty
DLP projector
Built-in Devices
Speaker
Projector
Brightness
3000 lumens
Contrast Ratio
2500:1
Image Size
68 cm - 7.9 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.8 - 2.2:1
Uniformity
85 %
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
87 Hz x 91.4 kHz
Bulb type
220 Watt
Controls & Adjustments
Keystone correction
High-bandwidth Digital Content Protection System (HDCP), 16:9 aspect ratio support
Lens
Lens Aperture
F/2.55-2.72
Zoom Type
Manual
Zoom Factor
1.15x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Input Device
External
1 x USB - 4 pin USB Type B , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A
Carrying case, lens cover, wireless remote control
1 x VGA cable , 1 x USB cable
Security Features
Security lock slot (cable lock sold separately), password protection
RoHS
280 Watt
Power Consumption Operational (Standby)
1 Watt
22 cm
17.8 cm
7.1 cm
1.4 kg
Limited warranty - 5 years
5 °C
0 - 80%
Sound Emission
33 dB
