Optoma EX525ST DLP XGA HD Short Throw Projector 2500 ANSI Lumens
Quicklinx: 74YMWS00 Mfr#: 95.8BB010E
The pinnacle of image excellence and flexible projection; the EX525ST produces large screen projection from short distances. At 2500 lumens, this native XGA projector pools impressive on-board technology for unbeatable performance on business and education platforms.
  • Vivid visuals
    Experience image clarity with a 2500 lumens brightness and a high 2500:1 contrast ratio, delivering vibrant visuals and deep blacks. The Optoma EX525ST's DLP projector technology ensures a sharp, high-quality display in a variety of lighting conditions.
  • Extensive connectivity
    Equipped with a wide range of inputs including VGA, S-Video, composite video, and DVI, the Optoma EX525ST offers versatile connectivity options. Whether it's a PC, media player, or any other device, connecting is seamless and straightforward.
  • Long-lasting performance
    With a lamp life cycle of up to 4000 hours in economic mode, the Optoma EX525ST is designed for durability and long-term use. This ensures consistent performance and reduces the need for frequent lamp replacements, making it a cost-effective solution for presentations and multimedia use.
  • Optimized for presentations
    The projector supports a native resolution of 1024 x 768 (XGA) and is capable of displaying 16.7 million colors, making it ideal for presentations and multimedia. The 4:3 native aspect ratio is perfect for PowerPoint presentations, and the projector's ability to support up to 1080i resolution means high-definition content looks crisp and clear.
  • Flexible installation
    Thanks to its vertical keystone correction of -20 / +20, setting up the Optoma EX525ST is hassle-free, allowing for quick adjustments to get the perfect image alignment. The projector's freestanding design focuses on stability and is suited for fixed installations in educational or professional settings.
Optoma EX525ST - DLP projector
DLP projector - 720p
Built-in Devices
Speaker
Brightness
2500 lumens
Contrast Ratio
2500:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
16.7 million colours
Bulb type
200 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (SECAM, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Digital Video Standard
Digital Visual Interface (DVI)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Video Output
RGB
Speakers
Speaker(s) - integrated
280 Watt
33.9 cm x 27.6 cm x 12.2 cm
4.3 kg
Built-in Devices
Speaker
Projector
Brightness
2500 lumens
Brightness (Reduced)
1500 lumens
Contrast Ratio
2500:1
Image Size
104 cm - 772 cm
Projection Distance
0.5 m - 3.7 m
Uniformity
80 %
Resolution
XGA - XGA (1024 x 768) (native) / 1400 x 1050 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
56 Hz x 91 kHz
Bulb type
200 Watt
Bulb life cycle
OSD Languages
Danish, Hungarian, Czech, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Arabic
High-bandwidth Digital Content Protection System (HDCP), 16:9 aspect ratio support
Lens
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
8 Watt
Speakers
1 x mixed channel
Input Device
External
1 x component video / RGB / SCART - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type B (management) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 (management) , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm
Lens cover, wireless remote control
1 x VGA cable - 1.8 m
Security Features
RoHS
280 Watt
Power Consumption Operational (Standby)
5 Watt
33.9 cm
27.6 cm
12.2 cm
4.3 kg
5 °C
35 °C
0 - 85%
Sound Emission
30 dB
28 dB
