Optoma EW610ST DLP WXGA 3D Ready HD 720p Projector - 3100 ANSI Lumens
Quicklinx: 7CMCWS00 Mfr#: EW610ST
  • High-Definition Multimedia Interface (HDMI)
The short throw, 3D capable EW610ST is designed to display bright, rich, colorful crystal clear wide images for both the education and business environments. It is perfect for installations with interactive whiteboards. Ensure teaching and business environments have the right tools for engaging and presenting to their audience without shadows and screen glare. The EW610ST at 3100L incorporates extensive connectivity, powerful 10W stereo speakers and RJ45 control to maintain and monitor the projectors over the network.
  • Saves money
    DLP ensures lower total cost of ownership, crystal clear graphics and improved reliability compared to other technologies.
  • Connect with ease
    The EW610ST easily connects to multiple devices such as DVD players and games consoles. Powerful 10W speaker, loud is enough for an average classroom or meeting room eliminating the need for costly external speakers. Simply connect power up and project for the big screen viewing experience.
  • Short throw lens
    The EW610ST can project an impressive 60" diagonal image from just 68cm from the screen. Stand alone or wall mounted the EW610ST eliminates shadows on the screen and allows you to present with ease.
  • The difference is widescreen
    The EW610ST is the perfect companion for widescreen laptops. Your presentations appear as sharp and detailed as they do on your widescreen laptop in WXGA (1280 x 800). WXGA resolution gives 30% more pixels than XGA.
  • Bright, detailed and colorful projection
    Grab your audience's attention with bright, vivid projected images thanks to the BrilliantColor technology incorporated within the EW610ST. Preset display modes allow you to achieve a perfect image on a variety of surfaces including screens and interactive whiteboards.
Optoma EW610ST - DLP projector - 3D
DLP projector - 720p
3D Capable
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
3100 lumens
Contrast Ratio
3000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Digital Video Standard
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
295 Watt
30.6 cm x 24.3 cm x 11.3 cm
3.1 kg
3-year warranty
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
3100 lumens
Contrast Ratio
3000:1
Image Size
113 cm - 567 cm
Projection Distance
0.5 m - 2.5 m
Throw Ratio
0.52:1
Uniformity
80 %
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 91 kHz
Bulb life cycle
OSD Languages
Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian
High-bandwidth Digital Content Protection System (HDCP), BrilliantColor, 16:9 aspect ratio support, Crestron RoomView
Lens
Lens Aperture
F/2.8-7.3
Zoom Type
Manual
Zoom Factor
2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Output Power / Channel
10 Watt
Input Device
External
1 x network - RJ-45 (management) , 1 x USB - mini-USB Type A (management) , 1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB / SCART - 15 pin HD D-Sub (HD-15) , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x microphone input - mini-phone 3.5 mm , 1 x serial RS-232 - 3 PIN mini-DIN (management) , 1 x composite video input - RCA , 2 x component video / audio input - RCA x 2 , 2 x audio line-in/out
Lens cover, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
RoHS
295 Watt
Power Consumption Operational (Standby)
1 Watt
Software Included
Drivers & Utilities
30.6 cm
24.3 cm
11.3 cm
3.1 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
5 °C
0 - 85%
Sound Emission
31 dB
29 dB
