The short throw, 3D capable EW610ST is designed to display bright, rich, colorful crystal clear wide images for both the education and business environments. It is perfect for installations with interactive whiteboards. Ensure teaching and business environments have the right tools for engaging and presenting to their audience without shadows and screen glare. The EW610ST at 3100L incorporates extensive connectivity, powerful 10W stereo speakers and RJ45 control to maintain and monitor the projectors over the network.
Saves money
DLP ensures lower total cost of ownership, crystal clear graphics and improved reliability compared to other technologies. -
Connect with ease
The EW610ST easily connects to multiple devices such as DVD players and games consoles. Powerful 10W speaker, loud is enough for an average classroom or meeting room eliminating the need for costly external speakers. Simply connect power up and project for the big screen viewing experience. -
Short throw lens
The EW610ST can project an impressive 60" diagonal image from just 68cm from the screen. Stand alone or wall mounted the EW610ST eliminates shadows on the screen and allows you to present with ease. -
The difference is widescreen
The EW610ST is the perfect companion for widescreen laptops. Your presentations appear as sharp and detailed as they do on your widescreen laptop in WXGA (1280 x 800). WXGA resolution gives 30% more pixels than XGA. -
Bright, detailed and colorful projection
Grab your audience's attention with bright, vivid projected images thanks to the BrilliantColor technology incorporated within the EW610ST. Preset display modes allow you to achieve a perfect image on a variety of surfaces including screens and interactive whiteboards.
- Optoma EW610ST - DLP projector - 3D
- DLP projector - 720p
- 3D Capable
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 3100 lumens
- Contrast Ratio
- 3000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 1080i, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 295 Watt
- 30.6 cm x 24.3 cm x 11.3 cm
- 3.1 kg
- 3-year warranty
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3100 lumens
- Contrast Ratio
- 3000:1
- Image Size
- 113 cm - 567 cm
- Projection Distance
- 0.5 m - 2.5 m
- Throw Ratio
- 0.52:1
- Uniformity
- 80 %
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91 kHz
- Bulb life cycle
- OSD Languages
- Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian
- High-bandwidth Digital Content Protection System (HDCP), BrilliantColor, 16:9 aspect ratio support, Crestron RoomView
Lens
- Lens Aperture
- F/2.8-7.3
- Zoom Type
- Manual
- Zoom Factor
- 2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Output Power / Channel
- 10 Watt
Input Device
- External
- 1 x network - RJ-45 (management) , 1 x USB - mini-USB Type A (management) , 1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB / SCART - 15 pin HD D-Sub (HD-15) , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x microphone input - mini-phone 3.5 mm , 1 x serial RS-232 - 3 PIN mini-DIN (management) , 1 x composite video input - RCA , 2 x component video / audio input - RCA x 2 , 2 x audio line-in/out
- Included Accessories
- Lens cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- RoHS
- Voltage Required
- 295 Watt
- Power Consumption Operational (Standby)
- 1 Watt
- Software Included
- Drivers & Utilities
- 30.6 cm
- 24.3 cm
- 11.3 cm
- 3.1 kg
- Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
- 5 °C
- 40 °C
- 0 - 85%
- Sound Emission
- 31 dB
- Sound Emission (Economic Mode)
- 29 dB
