Optoma EW531 DLP WXGA Projector 2600 ANSI Lumens
Quicklinx: 6KH9WS00 Mfr#: EW531
  • High-Definition Multimedia Interface (HDMI)
The bright 2600L, EW531 with 120Hz 3D Compatible technology is ideally partnered with a widescreen notebook and HD sources. Ceiling mounted or mobile this dual-purpose projector multi-tasks in both office, school and home environments. The environmentally friendly EW531 has energy saving features including <1W standby mode and auto power off saving you both time and money.
  • True WXGA resolution
    The EW531 is the perfect companion for widescreen laptops. Your presentations will appear as sharp and detailed as they do on your widescreen laptop in WXGA (1280 x 800). WXGA resolution gives 30% more pixels than XGA.
  • True HDMI
    Project crystal clear images using the latest HDMI v1.3 input. Hassle-free projection from a widescreen computer/HD source with a single HDMI cable - no need for separate audio cables.
  • Clear, focused images
    DarkChip3 technology from Texas Instruments produces a stunning 3000:1 contrast ratio for pin sharp graphics and crystal clear text. Crisper whites, ultra-rich blacks makes images come alive and text easier to read - ideal for business and education presentations.
  • Amazing colors
    The EW531 incorporates BrilliantColor technology to produce stunningly bright images with perfectly balanced life-like colors. Preset display modes allow you to achieve a perfect image on a variety of surfaces including screens and interactive whiteboards.
  • Environmentally friendly
    The EW531 incorporates energy saving features to conserve power and extend the lamp life.
Optoma EW531 - DLP projector - portable
DLP projector - 720p
Brightness
2600 lumens
Contrast Ratio
3000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
16.7 million colours
Bulb type
185 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Digital Video Standard
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Video Output
RGB
Speakers
Speaker(s) - integrated
233 Watt
28.6 cm x 19.2 cm x 8.4 cm
2.3 kg
Projector
Brightness
2600 lumens
Contrast Ratio
3000:1
Image Size
83 cm - 913 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.55 - 1.7:1
Uniformity
80 %
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
185 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Lens
Lens Aperture
F/2.5-2.67
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Input Device
External
1 x audio line-in - mini-phone 3.5 mm , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone 3.5 mm
Carrying case, lens cover, remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
RoHS
233 Watt
Power Consumption Operational (Standby)
1 Watt
28.6 cm
19.2 cm
8.4 cm
2.3 kg
5 °C
0 - 85%
