The bright 2600L, EW531 with 120Hz 3D Compatible technology is ideally partnered with a widescreen notebook and HD sources. Ceiling mounted or mobile this dual-purpose projector multi-tasks in both office, school and home environments. The environmentally friendly EW531 has energy saving features including <1W standby mode and auto power off saving you both time and money.
True WXGA resolution
The EW531 is the perfect companion for widescreen laptops. Your presentations will appear as sharp and detailed as they do on your widescreen laptop in WXGA (1280 x 800). WXGA resolution gives 30% more pixels than XGA. -
True HDMI
Project crystal clear images using the latest HDMI v1.3 input. Hassle-free projection from a widescreen computer/HD source with a single HDMI cable - no need for separate audio cables. -
Clear, focused images
DarkChip3 technology from Texas Instruments produces a stunning 3000:1 contrast ratio for pin sharp graphics and crystal clear text. Crisper whites, ultra-rich blacks makes images come alive and text easier to read - ideal for business and education presentations. -
Amazing colors
The EW531 incorporates BrilliantColor technology to produce stunningly bright images with perfectly balanced life-like colors. Preset display modes allow you to achieve a perfect image on a variety of surfaces including screens and interactive whiteboards. -
Environmentally friendly
The EW531 incorporates energy saving features to conserve power and extend the lamp life.
- Optoma EW531 - DLP projector - portable
- DLP projector - 720p
- Brightness
- 2600 lumens
- Contrast Ratio
- 3000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 16.7 million colours
- Bulb type
- 185 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 1080i, 480i, 576i, 576p
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 233 Watt
- 28.6 cm x 19.2 cm x 8.4 cm
- 2.3 kg
Projector
- Brightness
- 2600 lumens
- Contrast Ratio
- 3000:1
- Image Size
- 83 cm - 913 cm
- Projection Distance
- 1.2 m - 12 m
- Throw Ratio
- 1.55 - 1.7:1
- Uniformity
- 80 %
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 91.1 kHz
- Bulb type
- 185 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
Lens
- Lens Aperture
- F/2.5-2.67
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
Input Device
- External
- 1 x audio line-in - mini-phone 3.5 mm , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone 3.5 mm
- Included Accessories
- Carrying case, lens cover, remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- RoHS
- Voltage Required
- 233 Watt
- Power Consumption Operational (Standby)
- 1 Watt
- 28.6 cm
- 19.2 cm
- 8.4 cm
- 2.3 kg
- 5 °C
- 40 °C
- 0 - 85%
