Optoma ES521 DLP PROJECTOR SVGA 4:3
Quicklinx: 7KTFWS00 Mfr#: ES521
This ES521 projector produces sharp detailed presentations and graphics when used in the boardroom. Couple this with brightness in excess of ANSI lumens and this projector will produce stunning images for those using this projector in home entertainment environments with ambient light for a large screen experience.
The ES521 includes a wealth of energy saving features, automatic shut down and quick start-up and shut down. Optoma is committed to keeping the running costs of projectors as low as possible, but perhaps more importantly preserving valuable resources.
Optoma ES521 - DLP projector - portable
DLP projector
Microdisplay
DarkChip 3
Brightness
2700 lumens
Contrast Ratio
4500:1
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Bulb life cycle
Up to 5000 hour(s)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 525i, 525p, 625p, 625i, 576i, 576p
AC 120/230 V (50 - 60 Hz)
233 Watt
28.6 cm x 19.2 cm x 8.4 cm
2.3 kg
DLP projector
Projector
Microdisplay
DarkChip 3
Brightness
2700 lumens
Contrast Ratio
4500:1
Image Size
70 cm - 770 cm
Projection Distance
1.2 m - 12 m
Uniformity
85 %
Resolution
SVGA - SVGA (800 x 600)
Native Aspect Ratio
4:3
Bulb life cycle
Up to 5000 hour(s)
OSD Languages
Danish, Hungarian, Czech, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic
BrilliantColor, 16:9 aspect ratio support
Lens
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Modes
Input Device
External
1 x serial RS-232 , 1 x VGA input - 15 pin D-Sub (DB-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA
Carrying case, remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
233 Watt
Power Consumption Operational (Standby)
1 Watt
Software Included
Drivers & Utilities
28.6 cm
19.2 cm
8.4 cm
2.3 kg
5 °C
35 °C
0 - 80%
28 dB
