Utilizing the DLP technology, the EH300 delivers exceptional crystal-clear Full HD native resolution and immersive 3D visuals.
Producing a stunningly bright image with perfectly balanced vivid color, crystal clarity and exceptional light and shade detail only possible with a high contrast projector, the EH300 is perfect for projecting a broad range of applications including technical, advertising media and medical uses where detail matters.
Installed or on the move using the included carry bag, the versatile EH300 has a powerful on-board 16 W stereo speaker, HDMI connectivity and energy saving features including ECO mode and auto power off saving you both time and money for hassle-free, long-lasting projection.
- Optoma EH300 - DLP projector - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Stereo speakers
- Brightness
- 3500 lumens
- Contrast Ratio
- 15000:1
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb life cycle
- Up to 4000 hour(s) - normal mode ¦ Up to 6000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-K, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC, PAL-L, SECAM I)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 297 Watt
- 32.4 cm x 23.4 cm x 9.7 cm
- 3.1 kg
- 3D Capable
- Built-in Devices
- Stereo speakers
Projector
- Brightness
- 3500 lumens
- Contrast Ratio
- 15000:1
- Image Size
- 77 cm - 919 cm
- Projection Distance
- 1.2 m - 10 m
- Throw Ratio
- 1.5 - 1.8:1
- Uniformity
- 80 %
- Resolution
- UXGA - WUXGA (1920 x 1200) (native) / 1600 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 91 kHz
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- BrilliantColor, DynamicBlack technology, ProJect Green
Lens
- Lens Aperture
- F/2.55-2.87
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-K, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC, PAL-L, SECAM I
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 8 Watt
- Speakers
- 2 x right / left channel
- 2 x HDMI - 19 pin HDMI Type A , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB - 4 pin USB Type B (management) , 1 x 3D Sync out
- Included Accessories
- Carrying case, lens cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Security Slot Type
- Kensington security slot
- RoHS
- Voltage Required
- 297 Watt
- Power Consumption Stand by
- 0.5 Watt
- 32.4 cm
- 23.4 cm
- 9.7 cm
- 3.1 kg
- 5 °C
- 40 °C
- 0 - 85%
- Sound Emission (Economic Mode)
- 26 dB
