PWC projection screens are popular because they are inexpensive and easy to operate. Optoma manual screens offer several outstanding features.
- 92" Diagonal 16:9 Pull Down Screen
- Self-Locking Mechanism
- Dual Wall and Ceiling Mountable
- High Quality Screen Materials
Optoma's matte white fabric is composed of 4 different layers, including a sheet of weaved fibre-glass which helps stop static electricity and most importantly prevent wrinkles and waves. The screen fabric consists of a special material that helps prevent the loss of light, making it compatible with virtually every projector.
The fabrics are designed to be fire, water, and mold resistant and can be cleaned if required. The outside surface of the matte white screen has microdots that are made with PVC technology. This surface helps with creating the best possible reflection, whilst new advances in screen technology help keep our matte white screen flat and retain its shape and effectiveness over longer periods of time.
- Optoma PWC - projection screen - 92" (233.7 cm)
- Product Type
- Projection screen
- Placing / Mounting
- Ceiling mountable, wall mountable
- Projection Screen Image Diagonal Size
- 92" (233.7 cm)
- Projection Image Size
- 203 cm x 114.5 cm
- Aspect Ratio
- 16:9
- Screen Surface
- Matte White
- Product Material
- Aluminium, fabric, PVC, fibreglass
- 225 cm x 11.2 cm x 8.6 cm
- 11.3 kg
- 1-year warranty
- Designed For
- Optoma HZ40STx
- Product Type
- Projection screen
- Image Diagonal Size
- 92" (233.7 cm)
- Image Width
- 203 cm
- Image Height
- 114.5 cm
- Screen Surface
- Matte White
- Aspect Ratio
- 16:9
- Gain
- 1.0x
- Viewing Angle
- 160°
- Border Size
- 5 cm
- Extra Border Size
- 30 cm (top) & 6 cm (bottom)
- Product Material
- 225 cm - 11.2 cm - 8.6 cm
- 11.3 kg
- Mounting Kit
- Included
- Water-resistant, fire resistant, mould resistant, self-locking
- Limited warranty - 1 year
- Designed For
- Optoma HZ40STx
