The Full HD DH1017 produces crystal clear, bright images, perfect for a broad range of applications including technical, advertising media and medical training where detail really matters. Full support for Crestron Roomview, Telnet, Extron IP Link, AMX dynamic device discovery and PJ-Link protocols, allow almost all aspects of the DH1017 to be controlled across a network, keeping you in control, wherever you are. The environmentally friendly DH1017 has energy saving features including less than 0.5 W standby mode and auto power off saving you both time and money.
Virtually maintenance free = lower cost of ownership
DH1017 provides lower cost of ownership, longer life and improved reliability. The filter-free projector design does not require regular filter cleaning or filter replacement, saving you time and money. -
Full HD
Full HD (1920 x 1080) has more than twice the resolution of HD Ready (1280 x 720). DH1017 is compatible with HDTV broadcasts and high - definition media to project impressive full 1080p images and video in their original digital brilliance. -
Amazing colors
The DH1017 incorporates BrilliantColor technology to produce stunningly bright images with perfectly balanced life-like colors. -
RS232 control
The extensive RS232 command set makes it simple and easy to control the DH1017 with any control system. -
Extensive connectivity
This native 1080p projector accepts a wide variety of computer and video input signals. -
Clear, focused images
DarkChip3 technology from Texas instruments produces a stunning 10.000:1 contrast ratio for pin sharp graphics and crystal clear text. Crisper whites, ultra-rich blacks make images come alive and text easier to read. -
3D technology
Using the inherent speed of DLP technology, Optoma Full 3D projectors can output video and images at an astonishing rate of 120 Hz, allowing you to show full screen, full color, and stereoscopic 3D. The 3D effect is generated by splitting this signal into two standard video streams, one for each eye. -
Environmentally friendly
The DH1017 incorporates energy saving features to conserve power and extend the lamp life.
- Optoma DH1017 - DLP projector - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 4500 ANSI lumens
- Contrast Ratio
- 10000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- 310 Watt
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 370 Watt
- 32.6 cm x 25.4 cm x 10.4 cm
- 3.6 kg
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 4500 ANSI lumens
- Contrast Ratio
- 10000:1
- Image Size
- 72 cm - 867 cm
- Projection Distance
- 1.2 m - 12 m
- Throw Ratio
- 1.59 - 1.91:1
- Uniformity
- 85 %
- Resolution
- Full HD - Full HD (1920 x 1080) (native) / 1600 x 1200 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 144 Hz x 91 kHz
- Bulb type
- 310 Watt
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic
- sRGB colour profile, BrilliantColor, DynamicBlack technology, AMX Device Discovery, Auto Power Off, ProJect Green
Lens
- Lens Aperture
- F/2.5-2.76
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, component video, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 3 Watt
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 2 x HDMI - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management)
- Included Accessories
- Carrying case, lens cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- RoHS, WEEE
- Voltage Required
- 370 Watt
- Power Consumption Stand by
- 0.5 Watt
- 32.6 cm
- 25.4 cm
- 10.4 cm
- 3.6 kg
- 5 °C
- 45 °C
- 0 - 85%
- Sound Emission
- 28 dB
