Optoma DE-1123EGA Projection Screen Motorised
Quicklinx: BSD0WS00 Mfr#: DE-1123EGA
Accessory Type: Projection screen
Hurry, only 2 left in stock!
£828.19 ex VAT
£993.82 inc VAT
The EGA series screens offer a simple yet elegant design, with functionality the highest priority.
EGA screens utilize a single aluminum alloy construction, greatly increasing structural integrity making the screen sturdier and providing smoother operation.
Simple installation makes these screens suitable for most types of environments.
  • Optoma integrated control system
    The Optoma integrated control system includes an in-line switch, built-in remote control system, 12 V trigger, RS232 and external infrared receiver. This all-in-one integrated system guarantees a screen that is suitable for the most demanding applications.
  • Multi-functional mounting brackets
    The floating L-bracket design allows horizontal adjustments and therefore can be fixed at any preferred point on the screen casing.
  • Tubular motor
    The EGA's tubular motor ensures smooth, stable operation, and years of reliable and trouble-free use. The tubular motor operates quietly, with a noise level below 45 dB.
Optoma DE-1123EGA - projection screen - 123" (312 cm)
Projection screen - motorised
Placing / Mounting
Ceiling mountable, wall mountable
Package Content
IR remote control
Projection Screen Image Diagonal Size
123" (312 cm)
Projection Image Size
266 cm x 166 cm
Aspect Ratio
16:10
Screen Surface
Matte White
Product Material
Aluminium
298.3 cm x 10.8 cm x 11.3 cm
16 kg
Placing / Mounting
Package Content
IR remote control
Image Diagonal Size
123" (312 cm)
Image Width
266 cm
Image Height
166 cm
Screen Surface
Matte White
Aspect Ratio
16:10
Gain
1.0x
Border Size
5 cm
Extra Border Size
30 cm (top)
Black borders, tubular motor
Product Material
Aluminium
298.3 cm - 10.8 cm - 11.3 cm
16 kg
Brand: Optoma
Price Range Ex VAT: £750 - £1000
