Optoma Beige Ceiling Mount with Pole
Quicklinx: 8RWWWS00 Mfr#: OCM815W
Accessory Type: Mount
£58.65 ex VAT
£70.38 inc VAT
The OCM815W universal projector pole mount is ideal for high ceilings. Easy to set up with its unique design gives you everything you need for quick adjustment, the flexibility to fit almost any projector and hassle free projector maintenance. It's the perfect universal projector pole mount.
Optoma OCM815W mounting kit - for projector - white
Mounting kit - ceiling mountable
Mounting Components
Pole mount
Adjustable Height
57.5-82.5 cm
Adjustments
Pitch
Recommended Use
Projector
Max Load Weight
15 kg
White
Optoma DH351, DS320, DS322e, DW322, DX322, DZ500, EH416e, H117ST, H185X, H190X, HD145X, HZ40ST, HZ40STx, HZ48UST, S336, S371, S381, S400, S400LVe, UHD35, UHD35x, UHD38, UHZ50, UHZ65LV, W309ST, X340UST, X381, X400LV, ZU500USTE, ZU720TST, ZW400
Adjustable Height
57.5-82.5 cm
White
AV Furniture
Mounting kit
Mounting Components
Pole mount
Recommended Use
Projector
Placing / Mounting
Ceiling mountable
Cable Management
Integrated cable management
Adjustments
Pitch
Max Load Weight
15 kg
Adjustable height, rotating
Brand: Optoma
