Delivering Full HD image quality, the EH515 is ideal for conference rooms, large classrooms, lecture theaters, museums and houses of worship. This large venue projector boasts a brightness of 5,500 lumens and features multiple digital connection options, with two HDMI inputs and DisplayPort. For more complex installations, this projector is equipped with a large zoom range, lens shift and a built-in geometric adjustment feature - ideal for image stacking, uneven walls or where a projector placement is awkward and needs to be installed at an angle.
High contrast
Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications. -
Full 3D
Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the latest generation games consoles. Support for 144Hz rapid refresh rate provides ultra-smooth flicker free images. -
Full HD
Full HD (1920 x 1080) has more than twice the resolution of HD Ready (1280 x 720). EH515 is compatible with HDTV broadcasts and high-definition media to project impressive full 1080p images and video in their original digital brilliance. -
Integrated speaker
The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers. -
Energy saving
Using the specially designed lamp modes, you can reduce the power consumption by up to 70%. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance. -
Auto power off
There may be instances when the projector is left running when not in use. To help save energy, the "Auto Power Off" feature automatically turns off the projector after a set period of time if it is not being used. -
Eco AV mute
Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption by up to 70%, further prolonging the life of your lamp. -
Four-corner adjustment
Individually warp each corner of the image to create a perfectly square image. Ideal for image stacking, uneven walls or where projector placement is awkward and needs to be installed at an angle. -
Brightness matching
The brightness of a projector will vary throughout its life. To correctly match multiple units, the projector has set lamp power modes (stepped lamp dimming) to help match the brightness of both projectors. -
Large zoom range
A large zoom range enables multiple placement possibilities at a variety of distances from the projection screen. An advantage to this is that expensive interchangeable lens projectors can be substituted with a more cost effective solution whilst still retaining a diverse choice of positioning options. -
MHL
Turn your projector into a smart display by connecting your smartphone or tablet with a single cable using MHL, enabling you to view presentations and documents, stream videos and share photos on the big screen. -
Networking and control
Featuring a wide range of options you can remotely control and monitor the projector. -
BrilliantColor technology
For vibrant, natural looking images, Optoma projectors incorporate BrilliantColor multi-color processing technology. -
Wired remote
The wired remote connection allows all aspects of the projector to be individually controlled without requiring a line-of-sight to the projector; invaluable when using multiple units during live events.
- Optoma EH515 - DLP projector - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness
- 5500 ANSI lumens
- Contrast Ratio
- 10000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 365 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 525i, 525p, 625p, 625i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 425 Watt
- 42.4 cm x 34.4 cm x 16 cm
- 5.9 kg
- 3D Capable
- Networking
- Ethernet
Projector
- Brightness
- 5500 ANSI lumens
- Contrast Ratio
- 10000:1
- Image Size
- 69.1 cm - 765 cm
- Projection Distance
- 1.3 m - 8 m
- Throw Ratio
- 1.2 - 2.16:1
- Uniformity
- 80 %
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Max Sync Rate (V x H)
- 120 Hz x 91.146 kHz
- Bulb type
- 365 Watt
- Bulb life cycle
- BrilliantColor, PJlink, Crestron RoomView, 16:10 aspect ratio support, 4:3 aspect ratio support, AMX Device Discovery, ProJect Green, MHL compliance
Lens
- Lens Aperture
- F/2.5-3.39
- Zoom Type
- Manual
- Zoom Factor
- 1.8x
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Vertical Lens Shift
- 0% / 25%
- Horizontal Lens Shift
- 10% / 10%
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, component video, composite video, S-Video, RGB, MHL
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 20 Watt
- Speakers
- 1 x mixed channel
- 2 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) , 1 x DisplayPort - 20 pin DisplayPort , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 2 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone 3.5 mm , 1 x microphone input - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB (power only) - 4 pin USB Type A (power only) , 1 x USB - 4 pin USB Type B (management) , 1 x network - RJ-45 (management) , 1 x 3D Sync out , 1 x remote control
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Security Slot Type
- Kensington security slot
- RoHS
- Power Source
- AC
- Voltage Required
- 425 Watt
- Power Consumption Stand by
- 0.5 Watt
- 42.4 cm
- 34.4 cm
- 16 cm
- 5.9 kg
- Sound Emission (Economic Mode)
- 28 dB
