Optoma 4K400STX DLP Projector
Quicklinx: HDCBWS00 Mfr#: E9PV7KJ01EZ2
Portability: Non-portable
£1,334.49 ex VAT
£1,601.38 inc VAT
The Optoma 4K400STx short-throw projector allows you to capture large images in small spaces. This makes it ideal for small classrooms and meeting rooms.
Features of the projector are:
  • True 4K UHD resolution
  • Extensive connectivity options
  • 100" image from just over a meter away
  • Combination of high brightness and vivid colors
  • Illuminated remote control
Manufacturer Warranty - 5 years limited
  • Immersive audio experience
    With an integrated 10 W speaker, the Optoma 4K400STx projector delivers a mono sound output, enhancing presentations and multimedia experiences without the need for external speakers.
  • Vivid visuals
    Boasting a brightness of 4000 lumens and a contrast ratio of 1000000:1, this projector produces sharp, vibrant images even in well-lit environments. The Ultra HD 4K resolution ensures that every detail is crisp and clear.
  • Versatile connectivity
    Equipped with multiple interfaces including HDMI, SPDIF line-out, and USB power only, the Optoma 4K400STx offers flexible connection options for a variety of multimedia devices.
  • Advanced image adjustment
    Featuring both horizontal and vertical keystone correction, the projector allows for optimal image alignment, making it easy to set up in various spaces.
  • Long-lasting performance
    The projector lamp offers a life cycle of up to 15000 hours in dynamic mode, ensuring reliable performance and minimizing the need for frequent lamp replacements.
Optoma 4K400STx - DLP projector - short-throw - 3D
DLP projector - 4K
3D Capable
Yes (3D glasses sold separately)
Brightness
4000 lumens
Contrast Ratio
1000000:1
Resolution
3840 x 2160
Native Aspect Ratio
16:9
Lens
Short-throw fixed lens
Bulb type
240 watt
Bulb life cycle
Up to 4000 hour(s) - bright mode , Up to 10000 hour(s) - economic mode , Up to 15000 hour(s) - dynamic mode
Video Modes
480i, 480p, 576i, 576p, 720p, 1080i, 1080p, 2160p
Speakers
Speaker(s) - integrated
AC 100-240 V (50/60 Hz)
220 watt
31.5 cm x 27 cm x 11.8 cm
3.98 kg
DLP projector - 4K
3D Capable
Projector
Brightness
4000 lumens
Contrast Ratio
1000000:1
Image Size
93 cm - 763 cm
Projection Distance
0.4 m - 3.3 m
Throw Ratio
0.5:1
Uniformity
80 %
Resolution
Ultra HD 4K - 3840 x 2160
Native Aspect Ratio
16:9
Max Sync Rate (V x H)
120 Hz x 135 kHz
Bulb type
240 watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
English, French, German, Italian, Japanese, Portuguese, Russian, Chinese (simplified), Spanish
4:3 aspect ratio support, 4 ms input lag (1080p/240Hz), High Dynamic Range (HDR), Hybrid Log-Gamma (HLG), HDR10 compatibility, Amazing Color, Color Management System, ISF modes
Head and Stage
Head Type
7.51 mm
Lens
Focus Type
Manual
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-40 / +40
Horizontal Keystone Correction
-40 / +40
Video Input
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 watt
Speakers
1 x mixed channel
2 x HDMI input - 19 pin HDMI Type A , 1 x SPDIF line-out , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB (power only) - 4 pin USB Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x 12V programmable trigger
Backlit remote control, 2 x AAA batteries
Security Features
Security bar, security lock slot (cable lock sold separately), password protection
Security Slot Type
Kensington security slot
HDCP 2.2
Power Source
AC
220 watt
Power Consumption Stand by
0.5 watt
31.5 cm
27 cm
11.8 cm
3.98 kg
5 °C
0 - 85%
Sound Emission
24 dB
Brand: Optoma
Price Range Ex VAT: £1000 - £1500
