Optoma 46" Pull Up Projector Screen
LIGHT WEIGHT PORTABLE DESIGN!
Quicklinx: BH8DWS00 Mfr#: DP-9046MWL
Accessory Type: Projection screen
£196.05 ex VAT
£235.26 inc VAT
Marketing description is not available.
  • Fiberglass matte fabric
    A high-quality durable long-lasting screen material is comprised of four layers and incorporates top grade fiberglass as its main support layer. It features high resistance to temperature, fire, moisture, deformation and stretching. The overall material is also mildew-resistant and free from curving. The outer surface is infused with PVC microdots that help produce and reflect the best possible images with a wide and uniform 160-degree viewing angle. The fabric is certified by the world renowned Image Science Foundation for its superb performance.
  • Adjustable feet
    During use, two support feet twist out from under the casing. The feet come with height-adjustable pads for use on uneven surfaces.
  • Intelligent Interlock
    Designed for safe and secure transport, the intelligent interlock feature ensures the case automatically locks when the support bar is lifted or the screen is retracted.
Optoma DP-9046MWL - projection screen - 46" (117 cm)
Projection screen
Placing / Mounting
Desktop
Projection Screen Image Diagonal Size
46" (117 cm)
Projection Image Size
102 cm x 57.2 cm
Aspect Ratio
16:9
Screen Surface
Matte White
Product Material
Aluminium
112.4 cm x 14 cm x 8.4 cm
2.8 kg
1-year warranty
Projection screen
Placing / Mounting
Desktop
Image Diagonal Size
46" (117 cm)
Image Width
102 cm
Image Height
57.2 cm
Screen Surface
Matte White
Aspect Ratio
16:9
Gain
1.0x
Black borders
Product Material
Aluminium
112.4 cm - 14 cm - 8.4 cm
2.8 kg
Limited warranty - 1 year
Brand: Optoma
