Optoma 3500 ANSI WXGA UST Projector
Quicklinx: CVZYWS00 Mfr#: 60003842
Type: WXGA projector
Brightness: 3500ANSI lumens
Portability: Non-portable
£965.53 ex VAT
£1,158.63 inc VAT
NEC's UM351W is a 3500-lumen ultra-short throw projector that packs a multitude of features while delivering an extremely short throw distance for education and corporate applications. With its ability to be mounted to the wall directly above the screen on which it projects, this model helps eliminate the shadows and glare typically found with standard projection systems. The UM351W includes a powerful 20W speaker, closed captioning and RJ-45 for remote management over a network, and its input panel includes dual HDMI, VGA and a microphone input to amplify the presenter's voice.
NEC UM351W - LCD projector - ultra short-throw - LAN
LCD projector - 720p
Built-in Devices
Speaker
Brightness
3500 ANSI lumens
Contrast Ratio
4000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens
Ultra short-throw lens
Bulb type
255 Watt
Bulb life cycle
Up to 3800 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
344 Watt
37.8 cm x 42.8 cm x 11.2 cm
5.6 kg
3-year warranty
Built-in Devices
Speaker
Projector
Brightness
3500 ANSI lumens
Contrast Ratio
4000:1
Image Size
147.3 cm - 279.4 cm
Projection Distance
0.448 m - 0.854 m
Throw Ratio
0.36:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
255 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Micro Lens Array (MLA) Technology, wall colour correction, PJlink, Crestron RoomView, DICOM Simulation Mode, Direct Power Off, Auto Power Off, built-in test pattern, auto power on, USB Viewer, Carbon Savings Meter, USB Display, Virtual Remote, Auto Eco Mode, High Altitude Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.8
Zoom Factor
1.4x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-10 / +10
Horizontal Keystone Correction
-10 / +10
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
20 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
Wireless remote control, NEC NP04WK1 wall mounting kit
1 x VGA cable - 1.8 m
Security Features
Security lock slot (cable lock sold separately), security bar, keypad lock
TUV GS, RoHS, GOST-R, ERP
Power Source
AC
Nominal Voltage
344 Watt
Power Consumption Stand by
0.4 Watt
37.8 cm
42.8 cm
11.2 cm
5.6 kg
Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 6 months / 1000 hours
5 °C
20 - 80% (non-condensing)
Sound Emission
38 dB
28 dB
Brand: Optoma
Price Range Ex VAT: 750 - 1000
