Optoma 2800 Lumens Full HD Resolution DLP Technology Projector
Quicklinx: CXMSWS00 Mfr#: 95.8ZF01GC0E.LR
The EH200ST couples 1080p high resolution with bright, vibrant visuals to produce pin sharp graphics and crystal clear text - ideal for use in a classroom and meeting room. With a built-in speaker and two HDMI inputs the EH200ST is easy to setup and use. It can even be turned into a smart projector by connecting a smartphone or tablet with a single cable using MHL to view presentations and documents, stream videos and share images on the big screen.
  • Short throw projection
    With a short-throw lens, this projector can produce large screen sizes from a short distance. This means you can get a 100 inch image, with the projector placed just over a meter away from the screen or wall.
  • Full HD 1080p
    1080p resolution gives you sharp and detailed images from HD content without downscaling or compression; perfect for watching Blu-ray movies, HD broadcasting and playing video games.
  • Full 3D
    Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting and the games consoles. Support for 144 Hz rapid refresh rate provides ultra-smooth flicker free images.
  • High contrast
    Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
  • MHL connectivity
    Turn your projector into a smart display by connecting your smartphone or tablet with a single cable using MHL; now you can view presentations and documents, stream videos and share photos on the big screen.
  • Auto power off
    There may be instances when the projector is left running when not in use. To help save energy, the "auto power off" feature automatically turns off the projector after a set period of time if it is not being used.
  • Amazing colors
    For vibrant, natural looking images, Optoma projectors incorporate BrilliantColor multi-color processing technology.
  • Integrated speaker
    Complete your home entertainment experience with the convenience of a powerful built-in speaker. Built-in speakers provide exceptional sound quality and are easy to set up without the need for costly external speakers.
Optoma EH200ST - DLP projector - short-throw - portable - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DMD Chip
Brightness
3000 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Lens
Short-throw fixed lens
Bulb type
190 watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
(PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
233 watt
31.5 cm x 22.4 cm x 11.4 cm
2.65 kg
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DMD Chip
Brightness
3000 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
115 cm - 767 cm
Projection Distance
0.5 m - 3.35 m
Throw Ratio
0.49:1
Uniformity
80 %
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 91.146 kHz
Bulb type
190 watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Czech, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
BrilliantColor, 16:10 aspect ratio support, 4:3 aspect ratio support, Auto Power Off, MHL compliance
Lens
Lens Aperture
F/2.8
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Video Interfaces
HDMI, MHL
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 watt
Speakers
1 x mixed channel
1 x HDMI input - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x 3D Sync out - 3 PIN mini-DIN , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B (management)
Wireless remote control
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
Security Slot Type
Kensington security slot
RoHS
Power Source
AC
233 watt
Power Consumption Stand by
0.5 watt
31.5 cm
22.4 cm
11.4 cm
2.65 kg
5 °C
26 dB
