Futuristic technology, housed in a curved body with cosmic tones, takes your photography quality to new heights.
Timeless material for a timeless design
OPPO Find X5 Pro's streamlined curve is made possible with elegant ceramic. To create its premium finish, the body is polished in 14 processes over 269 minutes to capture the smoothness of pebble. While the 75° slope offers the optimal curve for illuminating the body in sunlight or shadow. -
Water rolls off its back
Complementing the complexity of OPPO Find X5 Pro's ceramic body is its durability. With IP68 water and dust resistance, you can forge your path without fear of the elements. -
4K Ultra Night Video: nurture the night's beauty
Record subjects at night in all their natural glory with clear and realistic image processing - and without overexposing the entire scene. Meanwhile, capture clearer voices, less background noise and more realistic soundscapes with Binaural Recording. -
Ultra HDR video: no fading into the background
Remember that dreamy sunset as vividly as it happened. Backgrounds and foregrounds show up clear and detailed without over exposure, even in backlit setups. -
Capture blink-of-an-eye moments in pristine clarity
Together with five-axis stabilization, ICE 2.0 turns runners sprinting to the finish or a dog playing with children into digital fragments of time. Forge life's moments into everlasting memories. -
1 Billion Color Bionic Display
Relive your highlights in spectacular detail on the 1 Billion Color Display. Enjoy smooth color transitions and moments that shine in pristine lifelike detail. -
120Hz dynamic refresh rate
The 120Hz dynamic refresh rate automatically adjusts for different tasks. When reading it rests to save power. But switch to a blockbuster movie and it sparks into life, for a silky smooth visual feast. -
Qualcomm Snapdragon 8 Gen 1
Featuring the flagship Qualcomm Snapdragon 8 Gen 1 processor, every application loads in a near instant. Watch a movie or join the gaming fray online in lightning-fast 5G. -
5000mAh battery
Peak performance with up to 1600 charging cycles, offering double the charging cycles of most phones. -
Customized cooling system
A next generation heat-dissipation system, with a super-large vapor chamber which is nearly 75% larger and cutting-edge 3D graphene films, helps the phone stay cool even during intensive tasks.
- OPPO Find X5 Pro - ceramic white - 5G smartphone - 256 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- CPH2305
- Display
- OLED display - 3216 x 1440 pixels - 6.7" - 525 ppi - (120 Hz) - 20.1:9 - flexible AMOLED - HDR - Corning Gorilla Glass Victus (scratch resistant glass)
- Processor
- Qualcomm Snapdragon 8 Gen 1 2.99 GHz (8-core)
- Neural Processor Unit (NPU)
- OPPO MariSilicon X
- Graphics Accelerator
- Qualcomm ADRENO 730
- Memory
- RAM 12 GB / Internal Memory 256 GB
- Operating System
- ColorOS 12.1 (based on Android 12)
- Main Camera
- 50 Megapixel - Exmor RS IMX766 - f/1.7 - focus: automatic
- Second Camera
- 50 Megapixel - Exmor RS IMX766 - ultra wide-angle lens - f/2.2
- Third Camera
- 13 Megapixel - Samsung S5K3M5 - 2x optical zoom - 52 mm - f/2.4
- Front Camera
- 32 Megapixel IMX709 sensor f/2.4 - focus free
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Wi-Fi 6, Bluetooth
- Security Devices
- Fingerprint reader (under display), face recognition
- Connectors
- USB-C
- Talk Time
- Up to 2400 minutes
- Standby Time
- Up to 475 hours
- Wireless Charging Standards
- Qi, AirVOOC
- Protection
- Dustproof, waterproof
- Ceramic white
- 73.9 mm x 8.5 mm x 163.7 mm
- 218 g
- Repairability Index
- 8.4 (out of 10)
- Specific Absorption Rate (SAR)
- 0.989 W/kg (head) , 1.272 W/kg (body) , 2.715 W/kg (limb)
- 2-year warranty
- Product Type
- Smartphone
- CPH2305
- Form Factor
- Touch
- Protection
- 73.9 mm
- 8.5 mm
- 163.7 mm
- 218 g
- Body Colour
- Ceramic white
- Body Material
- Aluminium alloy, polymer, ceramic coating
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Navigation
- GPS, A-GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Communications
- Data Transmission
- VoLTE, FDD-LTE, TDD-LTE, VoWiFi, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 6, Band 8, Band 19
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 800, 900, 800
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 34, Band 38, Band 39, Band 40, Band 41, Band 42, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2000, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n77, n78, n79, n40, n25, n12, n26, n13, n18
- 5G NR Frequency
- FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, TDD TD 3700, TDD TD 3500, TDD TD 4500, TDD 2300, FDD 1900, n12, FDD 850, n13, n18
- NFC, IEEE 802.11a/b/g/n/ac/ax, Bluetooth 5.2 BLE
Phone Features
- Sensors
- Accelerometer, proximity sensor, pedometer, magnetometer, gravity sensor, colour temperature sensor, brightness sensor, gyroscope
- Security Devices
- Additional Features
- MIMO technology, MU-MIMO technology, triple noise reduction microphones, X-axis haptic motor, Graphite + Ultra Large Steel Vapour Chamber
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, OGG, APE (Monkey's Audio), apt-X, LDAC, MID, SBC, apt-X HD, LHDC, APTX-TWS+
- Supported Digital Video Standards
- MKV, FLV, AVI, MOV, WMV, ASF, 3GP, H.264, H.265, MP4
- Sound Enhancements
- Dolby Atmos sound technology, 3D audio recording
- Clock Speed
- 2.99 GHz
- Processor Core Qty
- 8-core
- Artificial Intelligence Processor Family
- OPPO
- Artificial Intelligence Processor Model
- MariSilicon X
Graphics System
- RAM
- LPDDR5 SDRAM - 12 GB
- Internal Memory Capacity
- 256 GB
- Memory Interface
- UFS 3.1
Front Camera
- Sensor Resolution
- 32 Megapixel
- Sensor Size
- 1/2.74"
- Sensor Name
- Sony IMX709 sensor
- Lens Aperture
- F/2.4
- Lens Element Qty
- 5-element
- Focus Adjustment
- Focus free
- Field of View (FoV)
- 90 degree(s)
- Pixel Size
- 0.8 µm
- Special Effects
- Stickers
- Camera Modes
- Panorama, Time-lapse mode, Portrait, Night, dual-view
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps
- 3-axis electronic image stabilisation
Main Camera
- Sensor Resolution
- 50 Megapixel
- Sensor Size
- 1/1.56"
- Sensor Name
- Sony Exmor RS IMX766 sensor
- Optical Image Stabiliser
- 5-axis OIS (Optical Image Stabilisation)
- Lens Aperture
- F/1.7
- Lens Construction
- 6-element
- 80 degree(s)
- Pixel Size
- 1 µm
- Focus Adjustment
- Automatic
- Special Effects
- HDR, Bokeh effect, Stickers
- Camera Modes
- Burst mode, Panorama, Time-lapse mode, Slow motion mode, Pro mode, night mode, portrait mode, AI Beauty, Cinema mode, Macro mode, Dual-View Video, RAW+ mode, dual-view, High-res, Text scanner, Xpan mode
- Light Source
- LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 30 fps, 1280 x 720 (720p) at 60 fps, 3840 x 2160 (4K) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, Slo-mo video 1280 x 720 (720p) at 480 fps
- Phase Detect Auto-Focus (PDAF), Corning Gorilla Glass (protective lens glass), contrast detection auto-focus (CDAF), Google Lens, 1G6P lens
Second Camera
- Sensor Resolution
- 50 Megapixel
- Sensor Size
- 1/1.56"
- Sensor Name
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- Lens Element Qty
- 7-element
- 110 degree(s)
- Pixel Size
- 1 µm
- Phase Detect Auto-Focus (PDAF), Electronic Image Stabiliser (EIS), 4cm macro photography, contrast detection auto-focus (CDAF)
Third Camera
- Sensor Resolution
- 13 Megapixel
- Sensor Size
- 1/3.4"
- Sensor Name
- Samsung S5K3M5
- Optical Zoom
- 2x
- Digital Zoom
- 20x
- Hybrid Zoom
- 5x
- Lens Aperture
- F/2.4
- Min Focal Length
- 52 mm
- Pixel Size
- 1 µm
- Lens Element Qty
- 5-element
- Electronic Image Stabiliser (EIS)
Display
- OLED display
- Technology
- Flexible AMOLED
- Diagonal Size
- 6.7"
- Display Resolution
- Display Format
- QHD+
- Pixel Density
- 525 ppi
- Aspect Ratio
- 20.1:9
- Max Brightness
- 1300 cd/m²
- Colour Depth
- 1.07 billion colours
- HDR
- HDR Technology
- HDR10+
- Enhancement Technology
- Eye comfort mode, SDR-to-HDR colour enhancement, resolution enhancer, Bedtime Mode
- Refresh Rate
- 120 Hz
- Touch Sampling Rate
- 1000 Hz
- Contrast Ratio
- 12000000:1
- Protection
- Always-on display, Dark mode, DisplayMate A+, 100% DCI-P3, 100% sRGB, 71% NTSC, 97% NTSC, Max brightness level: 8912, 104% NTSC
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 5000 mAh
- Fast Charging Technology
- SuperVOOC Flash Charge technology, SuperVOOC 2.0 Flash Charge, SuperVOOC 3.0 Flash Charge
- Wireless Charging
- Qi, AirVOOC
- Talk Time
- 2400 minutes
- Standby Time
- 475 hours
- Run Time Details
- Talk (2G): up to 2400 min , Talk (4G): up to 1740 min , Standby: up to 475 hrs , Playback (Music): up to 40 hrs , Playback (video): up to 24 hrs
- IP68
- Included Accessories
- SIM card removal tool, USB-C charging cable, protective film, SuperVOOC 80W power adapter, USB-A to USB-C adapter
- Limited warranty - 2 years
Sustainability Information
- 8.4 (out of 10)
