The Clarity To See More
Lifelike details at your fingertips. Made possible with Oppo Find X5 Lite's ultra high resolution 64MP rear camera trio and the Sony powered 32MP front camera.
Stun your social circles with Ultra-Clear 108MP Image - the unreal high-resolution is made possible thanks to the proprietary super-resolution algorithm. Zoom in and discover the endless details 108MP can offer.
Galactic rays with Laser Direct Imaging
It features the industry's first-ever LDI (Laser Direct Imaging)-processed design. Lay your eyes on the field of shimmering micron-level patterns that's inspired by breathtaking meteor showers.
Made for Viewing
A big, fluid, and vivid display brought to you by the super-fast 90Hz refresh rate. Immerse yourself into the digital world without worrying about straining your eyes with the SGS Eye Care certified display.
You're the portrait pro
Look up, smile, and pose - you don't need fancy gadgets for DSLR-like portraits with a delicately blurred background. With Portrait Mode's 25 levels of adjustable aperture, you can custom-create your perfect, pro-level portrait on the go. -
Capture both sides of the fun
Who says the photographer can't be in the frame? Tap the split-screen layout that catches your eye in Dual-View Video and record from both sides of the camera simultaneously. -
See in details
Stun your social circles with Ultra-Clear 108MP Image - the unreal high-resolution is made possible thanks to the proprietary super-resolution algorithm. Zoom in and discover the endless details 108MP can offer. -
It features the industry's first-ever LDI (Laser Direct Imaging)-processed design. Lay your eyes on the field of shimmering micron-level patterns that's inspired by breathtaking meteor showers. -
Made for viewing
A big, fluid, and vivid display brought to you by the super-fast 90Hz refresh rate. Immerse yourself into the digital world without worrying about straining your eyes with the SGS Eye Care certified display. -
Power up in minutes
Don't wait to get in the game. With 65W SUPERVOOC, you only need a five-minute charge to play your favorite game and 31 minutes to fully power up the big 4500mAh battery. -
Get your 5G game on
The octa-core MediaTek Dimensity 900 5G processor and its industry-leading 6nm process welcome you into the 5G world. Made available with the ultra-fast Wi-Fi 6, say farewell to loading - it's a thing of the past.
- OPPO Find X5 Lite - starry blue - 5G smartphone - 256 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- CPH2371
- Display
- OLED display - 2400 x 1080 pixels - 6.43" - 409 ppi - (90 Hz) - 20.1:9 - Rigid AMOLED - HDR - Corning Gorilla Glass 5 (scratch resistant glass)
- Processor
- MediaTek Dimensity 900 2.4 GHz (8-core)
- Graphics Accelerator
- ARM Mali-G68 MC4
- Memory
- RAM 8 GB / 256 GB
- Supported Memory Card
- microSDXC slot - up to 1 TB
- Operating System
- ColorOS 12 (based on Android 11)
- Main Camera
- 64 Megapixel - Omnivision OV64B - f/1.7 - focus: automatic
- Second Camera
- 8 Megapixel - IMX355 sensor - ultra wide-angle lens - f/2.2
- Third Camera
- 2 Megapixel - f/2.4
- Front Camera
- 32 Megapixel IMX615 sensor f/2.4 - focus free
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Wi-Fi 6, Bluetooth
- Security Devices
- Fingerprint reader (under display), face recognition
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 2280 minutes
- Standby Time
- Up to 350 hours
- Wireless Charging Standards
- Qi, AirVOOC
- Starry blue
- 73.2 mm x 7.81 mm x 160.6 mm
- 173 g
- Specific Absorption Rate (SAR)
- 0.855 W/kg (head) , 1.134 W/kg (body) , 2.782 W/kg (limb)
- 2-year warranty
- Product Type
- Smartphone
- CPH2371
- Form Factor
- Touch
- 73.2 mm
- 7.81 mm
- 160.6 mm
- 173 g
- Body Colour
- Starry blue
- Body Material
- Fibreglass, polymer
- SAR Value
- 1.134 W/kg (body), 0.855 W/kg (head), 2.782 W/kg (limb)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Navigation
- GPS, A-GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Communications
- Data Transmission
- VoLTE, FDD-LTE, TDD-LTE, VoWiFi, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 6, Band 8, Band 19
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 800, 900, 800
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 38, Band 39, Band 40, Band 41, Band 42, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n3, n5, n7, n8, n20, n28, n38, n41, n66, n77, n78, n40
- 5G NR Frequency
- FDD 2100, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, TDD TD 3700, TDD TD 3500, TDD 2300
- NFC, IEEE 802.11a/b/g/n/ac/ax, Bluetooth 5.2 BLE
Phone Features
- Sensors
- Accelerometer, proximity sensor, pedometer, magnetometer, gravity sensor, brightness sensor, gyroscope
- Security Devices
- Additional Features
- MIMO technology, Dual noise reduction microphones
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, OGG, APE (Monkey's Audio), apt-X, LDAC, MID, SBC, apt-X HD, LHDC, APTX-TWS+
- Supported Digital Video Standards
- MKV, FLV, AVI, MOV, WMV, ASF, 3GP, MP4
- Sound Enhancements
- Dolby Atmos sound technology
- Clock Speed
- 2.4 GHz
- Processor Core Qty
- 8-core
Graphics System
- ARM Mali-G68 MC4
- RAM
- LPDDR4X SDRAM - 8 GB
- Internal Memory Capacity
- 256 GB
- Memory Interface
- UFS 2.2
- Supported Flash Memory Cards
- microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
- 32 Megapixel
- Sensor Size
- 1/2.74"
- Sensor Name
- Sony IMX615 sensor
- Lens Aperture
- F/2.4
- Lens Element Qty
- 5-element
- Focus Adjustment
- Focus free
- Field of View (FoV)
- 85 degree(s)
- Pixel Size
- 0.8 µm
- Special Effects
- Stickers
- Camera Modes
- Panorama, Time-lapse mode, Portrait, Night, dual-view
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps
- 3-axis electronic image stabilisation
Main Camera
- Sensor Resolution
- 64 Megapixel
- Sensor Size
- 1/2"
- Sensor Name
- Omnivision OV64B sensor
- Lens Aperture
- F/1.7
- Lens Construction
- 6-element
- 80.5 degree(s)
- Pixel Size
- 0.7 µm
- Focus Adjustment
- Automatic
- Digital Zoom
- 20x
- Special Effects
- HDR, Bokeh effect, Stickers
- Camera Modes
- Burst mode, Panorama, Time-lapse mode, Slow motion mode, Expert Mode, Portrait, Night, Extra HD, Movie Mode, Text scanner
- Light Source
- LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps, 1280 x 720 (720p) at 60 fps
- Electronic Image Stabiliser (EIS), Ultra Steady Video
Second Camera
- Sensor Resolution
- 8 Megapixel
- Sensor Size
- 1/4"
- Sensor Name
- Sony IMX355 sensor
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- Lens Element Qty
- 5-element
- 119 degree(s)
- Pixel Size
- 1.12 µm
Third Camera
- Sensor Resolution
- 2 Megapixel
- Sensor Size
- 1/5"
- Lens Aperture
- F/2.4
- 88.8 degree(s)
- Pixel Size
- 1.75 µm
- Lens Element Qty
- 3-element
Display
- OLED display
- Technology
- Rigid AMOLED
- Diagonal Size
- 6.43"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 409 ppi
- Aspect Ratio
- 20.1:9
- Max Brightness
- 800 cd/m²
- Colour Depth
- 16.7 million colours
- HDR
- HDR Technology
- HDR10+
- Enhancement Technology
- Eye comfort mode, Bedtime Mode
- Refresh Rate
- 90 Hz
- Touch Sampling Rate
- 180 Hz
- Contrast Ratio
- 1200000:1
- Protection
- Dark mode, 12000000:1 (max HDR) contrast ratio, 100% DCI-P3, 135% sRGB, 76% DCI-P3, 103% sRGB
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 4800 mAh
- Fast Charging Technology
- SuperVOOC Flash Charge technology, SuperVOOC 2.0 Flash Charge, SuperVOOC 3.0 Flash Charge, Power Delivery
- Wireless Charging
- Qi, AirVOOC
- Talk Time
- 2280 minutes
- Standby Time
- 350 hours
- Run Time Details
- Talk: up to 2280 min , Standby: up to 350 hrs , Playback (Music): up to 38 hrs , Playback (video): up to 16 hrs
- Recharge Time
- 34 min
- IPX4, SGS Low Blue Light Certification, Netflix HD Certification, Amazon Prime Video HD Certification
- Included Accessories
- SIM card removal tool, USB-C charging cable, protective film, SuperVOOC 65W power adapter, USB-A to USB-C adapter
- Limited warranty - 2 years
