Damaged Box
This device will arrive in original packaging, however the box will show signs of damage.
It is a brand new, unlocked device. Original factory-seal unbroken.
Oppo UK 2 Year Warranty.
Oppo Find X3 Pro
Capture the colors of the world in their truest form with the revolutionary Find X3 Pro. Rich tones and deep hues combine to illuminate the road to the future.
Enrich Life with 1 Billion+ Colours
Discover the limitless potential of colour-rich photography and video. Shoot, save and view in maximum colour vibrancy, and dive into an incredible spectrum of 1.07 billion colours — all right there in the palm of your hand.
Prismatic Colour Under the Skin
Find X3 Pro’s 10-bit Full-Path Colour Engine ensures utterly flawless colour transitions, from skin tones to skies and sunsets — so you capture reality in all its radiance.
Colour Vision Enhancement
OPPO used the personalized hue test to develop colour compensation for Find X3 Pro, resulting in heightened colour differentiation and recognition. Find X3 Pro’s colour compensation technology allows those with Colour Vision Deficiency (CVD) to see colour-corrective hues and deeper contrast levels for colour differentiation.
Unfazed by Splashes
Find X3 Pro is IP68 Water and Dust Resistance — designed to withstand splashes, spills and the next adventure, so you can forge your path without restraint.
The Power of 4 Cameras Capture Every Moment:
Ultra-Wide-Angle
Wide
Microlens
Telephoto
Moments to Memories
Find X3 Pro’s 32MP front selfie camera performs like a main camera, with night mode support — so you and your loved ones can turn the moment into a memory even in the most spontaneous circumstances.
Inspired by spacecraft
Born of most advanced engineering and sky-high technical craftsmanship, Find X3 Pro effortlessly blends tasteful design with futuristic instincts. -
All eyes on future
In a world that never stands still, OPPO's design studio is always looking to the future. Find X3 Pro's impossibly streamlined curves artfully evoke spacecraft and the technology of tomorrow. -
Glass shaped to vision
The camera module's elegant Gradient Arc Camera neutralizes the single-sheet glass rear panel with a fluid curve - rendering the phone's sleek contours a natural complement to your own style. -
Unfazed by splashes
Find X3 Pro is IP68 water and dust resistance - designed to withstand splashes, spills and the next adventure, so you can forge your path without restraint. -
Expand your field of vision
Find X3 Pro's ultra-wide-angle lens has a 110.3° field of vision, avoiding compromise in image quality or distortion at the edges of the photograph - perfect for group shots or capturing landscapes in their full glory. -
Curiosity amplified
Find X3 Pro's microlens camera offers a closer look at things which can't be seen directly by the naked eye - up to 60x closer. Take it as an invitation to find new perspectives amid the seemingly ordinary.
- OPPO Find X3 PRO - gloss black - 5G smartphone - 256 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- CPH2173
- Display
- OLED display - 3216 x 1440 pixels - 6.7" - 525 ppi - (120 Hz) - 20.1:9 - AMOLED (LTPO) - HDR - Corning Gorilla Glass 5 (scratch resistant glass)
- Processor
- Qualcomm Snapdragon 888 2.84 GHz (8-core)
- Graphics Accelerator
- Qualcomm ADRENO 660
- Memory
- RAM 12 GB / 256 GB
- Operating System
- ColorOS 11.2 (based on Android 11)
- Main Camera
- 50 Megapixel - Exmor RS IMX766 24 mm - f/1.8 - focus: automatic
- Second Camera
- 50 Megapixel - Exmor RS IMX766 - ultra wide-angle lens 15 mm - f/2.2
- Third Camera
- 13 Megapixel - Samsung S5K3M5 - telephoto lens - 2x optical zoom - 52 mm - f/2.4
- Fourth Camera
- 3 Megapixel - microlens 15 mm - f/3.0
- Front Camera
- 32 Megapixel Exmor RS IMX615 f/2.4
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Wi-Fi 6, Bluetooth
- Security Devices
- Fingerprint reader (under display), face recognition
- Connectors
- USB-C
- Talk Time
- Up to 1488 minutes
- Standby Time
- Up to 398.7 hours
- Wireless Charging Standards
- Qi, AirVOOC
- Protection
- Dustproof, water-resistant
- Gloss black
- 74 mm x 8.26 mm x 163.6 mm
- 193 g
- Specific Absorption Rate (SAR)
- 0.892 W/kg (head) , 1.318 W/kg (body) , 2.707 W/kg (limb)
- 2-year warranty
- Product Type
- Smartphone
- CPH2173
- Form Factor
- Touch
- Protection
- 74 mm
- 8.26 mm
- 163.6 mm
- 193 g
- Body Colour
- Gloss black
- Body Material
- Aluminium alloy, polymer, Corning Gorilla Glass 5
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Navigation
- GPS, A-GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Communications
- Data Transmission
- VoLTE, FDD-LTE, TDD-LTE, VoWiFi, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 6, Band 8, Band 19
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 800, 900, 800
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 42, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n3, n5, n7, n8, n20, n28, n38, n41, n77, n78, n79, n40
- 5G NR Frequency
- FDD 2100, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, TDD TD 3700, TDD TD 3500, TDD TD 4500, TDD 2300
- NFC, IEEE 802.11a/b/g/n/ac/ax, Bluetooth 5.2
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, pedometer, digital compass, magnetometer, gyro sensor, gravity sensor, colour temperature sensor
- Security Devices
- Additional Features
- MIMO technology, MU-MIMO technology, Google Lens, Haptic vibration motor, dual stereo speakers, steam chamber + graphite cooling, triple noise reduction microphones
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, OGG, APE (Monkey's Audio), LDAC, MID, SBC, LHDC
- Supported Digital Video Standards
- MKV, FLV, AVI, MOV, WMV, ASF, 3GP, H.265, MP4
- Sound Enhancements
- Dolby Atmos sound technology, Qualcomm aptX audio, Qualcomm TrueWireless Stereo Plus, Qualcomm aptX HD audio
- Clock Speed
- 2.84 GHz
- Processor Core Qty
- 8-core
Graphics System
- RAM
- LPDDR5 SDRAM - 12 GB
- Internal Memory Capacity
- 256 GB
- Memory Interface
- UFS 3.1
Front Camera
- Sensor Resolution
- 32 Megapixel
- Sensor Size
- 1/2.74"
- Sensor Name
- Sony Exmor RS IMX615 sensor
- Lens Aperture
- F/2.4
- Lens Element Qty
- 5-element
- Min Focal Length
- 25 mm
- Field of View (FoV)
- 81 degree(s)
- Pixel Size
- 0.8 µm
- Special Effects
- Stickers
- Camera Modes
- Panorama, Time-lapse mode, night mode, Portrait
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps
- Still Image Resolutions
- 6560 x 4928
- Electronic Image Stabiliser (EIS)
Main Camera
- Sensor Resolution
- 50 Megapixel
- Sensor Size
- 1/1.56"
- Sensor Name
- Sony Exmor RS IMX766 sensor
- 4096 x 3072, 4096 x 2304, 3072 x 3072, 8192 x 6144, 4096 x 1834
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Aperture
- F/1.8
- Lens Construction
- 6-element
- Min Focal Length
- 24 mm
- Pixel Size
- 1 µm
- Focus Adjustment
- Automatic
- Special Effects
- HDR, Live HDR, Bokeh effect, Stickers
- Camera Modes
- Burst mode, Panorama, Time-lapse mode, Slow motion mode, night mode, Expert Mode, portrait mode, AI Beauty, Text, Cinema mode, Filter mode, Macro mode, Dual-View Video, Ultra Night Video, AI Highlight Video, passport photo, RAW+ mode, Colour Vision Enhancement
- Light Source
- LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 30 fps, 1280 x 720 (720p) at 60 fps, 3840 x 2160 (4K) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, Slo-mo video 1280 x 720 (720p) at 480 fps
- Electronic Image Stabiliser (EIS), 3D audio recording, omnidirectional autofocus, 2x2 On-Chip Lens (OCL), (DOL-HDR) Digital Overlap High Dynamic Range, 10-bit 4K HDR video, LOG video (Rec. 2020)
Second Camera
- Sensor Resolution
- 50 Megapixel
- Sensor Size
- 1/1.56"
- Sensor Name
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- Min Focal Length
- 15 mm
- Lens Element Qty
- 7-element
- 110 degree(s)
- Pixel Size
- 1 µm
- Electronic Image Stabiliser (EIS), omnidirectional autofocus, 2x2 On-Chip Lens (OCL), 4cm macro photography
Third Camera
- Sensor Resolution
- 13 Megapixel
- Sensor Size
- 1/3.4"
- Sensor Name
- Samsung S5K3M5
- Optical Zoom
- 2x
- Digital Zoom
- 20x
- Hybrid Zoom
- 5x
- Lens Type
- Telephoto lens
- Lens Aperture
- F/2.4
- Min Focal Length
- 52 mm
- Pixel Size
- 1 µm
- Lens Element Qty
- 5-element
Fourth Camera
- Sensor Resolution
- 3 Megapixel
- Sensor Size
- 1/5"
- Lens Type
- Microlens
- Lens Aperture
- F/3.0
- Min Focal Length
- 15 mm
- Pixel Size
- 1.12 µm
- Lens Element Qty
- 4-element
- Magnification x60
Display
- OLED display
- Technology
- AMOLED (LTPO)
- Diagonal Size
- 6.7"
- Display Resolution
- Display Format
- QHD+
- Pixel Density
- 525 ppi
- Aspect Ratio
- 20.1:9
- Max Brightness
- 1200 cd/m²
- Colour Depth
- 1.07 billion colours
- HDR
- HDR Technology
- HDR10+
- Enhancement Technology
- SDR-to-HDR colour enhancement, resolution enhancer
- Refresh Rate
- 120 Hz
- Contrast Ratio
- 5000000:1
- Protection
- Night mode, AOD(Always On Display), Dark mode, O1 Ultra Vision Engine, DisplayMate A+, 240Hz sampling rate, 12000000:1 (max HDR) contrast ratio, O-Sync Display Hyper Response Engine, 8192-Level Natural Brightness
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 4500 mAh
- Fast Charging Technology
- VOOC Flash Charge technology 3.0, SuperVOOC 2.0 Flash Charge
- Wireless Charging
- Qi, AirVOOC
- Talk Time
- 1488 minutes
- Standby Time
- 398.7 hours
- Run Time Details
- Standby: up to 398.7 hrs , Playback (video): up to 14.3 hrs , Talk (3G): up to 1488 min , Playback (audio (via speakers)): up to 36.9 hrs
- Recharge Time
- 35 min
- IP68
- Included Accessories
- Headset, protective cover, SIM card removal tool, USB-C cable, SuperVOOC 65W power adapter
- Limited warranty - 2 years
