Oppo A15 32GB Android Smartphone - Blue
Quicklinx: G3GJWS00 Mfr#: CPH2185BLU
  • microSDHC
  • microSD
  • Android
The Can-Do Camera
13MP AI Triple Rear Camera
OPPO A15's AI Triple Rear Camera can capture any photo you dream of. The 13MP main lens preserves clarity, the 2MP macro lens captures fine details up close, and the 2MP depth lens makes every portrait perfect.
ULTRA CLEAR TRIPLE CAMERA:With 13MP wide-angle camera, 2MP macro camera for close-ups and 2MP mono camera, taking photos is more versatile than ever before. The 5 MP front camera also ensures quick selfies
Beauty that's All Yours
5MP Front AI Beautification
Through OPPO's self-developed Front AI Beautification, OPPO A15 showcases your unique beauty in every selfie. After identifying gender, age, and region, a custom solution perfects skin tone and complexion for each face.
A Screen to Sink Your Eyes Into
16.55cm(6.52‘’)Waterdrop Eye Protection Screen
A screen this size makes every video a big experience. Even under bright sunlight, every detail is easy to see.
Brilliant display: with its 6.5 inch HD+ display and 16 million colours, the OPPO A15 ensures an ultra-clear display. The narrow edges ensure a larger screen area.
Slim, Sleek, and So Very Holdable
Thinner Curved Body
With its 3D back cover and slimmed-down profile, OPPO A15 both looks good and feels good in your hand.
Flexible Storage: Dual SIM slots allow you to use 2 SIM cards to separate private and professional. Thanks to the microSD card, the memory can be expanded up to 256 GB Large battery: thanks to 4,230 mAh battery + 10 W fast charge, the OPPO A15 has an ultra-long battery life and can be used for a long time on the go without the need for a power bank Smart design: the OPPO A15 is characterised by its slim, handy shape of 7.9 mm and a weight of 175 g. On the back there is a fingerprint sensor
  • 13MP AI Triple Rear Camera
  • 5MP Front AI Beautification
  • Portrait bokeh
    Hardware-level bokeh blurring makes your subject stand out and lets the background naturally fade into a soft blur.
  • HDR
    Even in backlighting, HDR can keep you looking clear while also preserving background details.
  • AI Scene Enhancement
    AI Scene Enhancement identifies 21 types of scenes and chooses just the right solution for each one, giving your photos more impact.
  • Macro lens
    From flowers to food, capture the tiniest details in vibrant clarity from a distance as small as 4 cm.
  • Thinner curved body
  • Just like that, you're in
    Equipped with Fingerprint Sensor and AI Face Unlock, OPPO A15 can be unlocked with just a touch or a glance. OPPO's advanced facial recognition identifies you based on 128 facial features, giving you access in an instant.
  • Smart sidebar
    Access files, take screenshots, and more, all from the app currently in use.
  • Icon pull-down gesture
    Pull-down icons, make it easier for single-hand operation.
OPPO A15 - blue mystery - 4G smartphone - 32 GB - GSM
4G smartphone
Manufacturer Model Number
CPH2185
Display
LCD display - 1600 x 720 pixels - 6.52" - 269 ppi - (60 Hz) - LCD
MediaTek Helio P35 MT6765 / 2.3 GHz
Graphics Accelerator
IMG GE8320
RAM 3 GB / 32 GB
Supported Memory Card
microSDXC slot - up to 256 GB
Operating System
ColorOS 7.2 (based on Android 10)
Main Camera
13 Megapixel - f/2.2 - focus: automatic
Second Camera
2 Megapixel - f/2.4 - macro camera
Third Camera
2 Megapixel - f/2.4 - depth camera
Front Camera
5 Megapixel f/2.4
Service Provider
Not specified
SIM Card
Single-SIM - nano SIM
Wireless Interface
Wi-Fi, Bluetooth
Connectors
3.5 mm headset jack, Micro-USB
Blue mystery
75.4 mm x 7.9 mm x 164 mm
175 g
0.92 W/kg (head) , 1.16 W/kg (body) , 2.77 W/kg (limb)
Smartphone
CPH2185
Touch
75.4 mm
7.9 mm
164 mm
175 g
Body Colour
Blue mystery
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Navigation
GPS, A-GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Qty
Single-SIM
Input Device
Multi-touch
Communications
Data Transmission
FDD-LTE, TDD-LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 5, Band 8
3G UMTS Frequency
2100, 850, 900
4G LTE Band
Band 1, Band 3, Band 5, Band 7, Band 8, Band 20, Band 28, Band 38, Band 40, Band 41
4G LTE Frequency
FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500
Wireless Interface
Wi-Fi, Bluetooth 5.0
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Media Player
Supported Digital Audio Standards
AAC, apt-X, LDAC, SBC
MediaTek Helio P35
Processor Number
MT6765
Clock Speed
2.3 GHz
Graphics System
IMG GE8320
RAM
LPDDR4X SDRAM - 3 GB
Internal Memory Capacity
32 GB
Supported Flash Memory Cards
microSDHC, microSD, microSDXC - up to 256 GB
Front Camera
Sensor Resolution
5 Megapixel
Lens Aperture
F/2.4
Lens Element Qty
3-element
AI beautification
Main Camera
Sensor Resolution
13 Megapixel
Lens Aperture
F/2.2
Lens Construction
5-element
Focus Adjustment
Automatic
Camera Modes
Panorama, Time-lapse mode, Slow motion mode, Expert Mode, Portrait, Night
Light Source
LED flash
Second Camera
Sensor Resolution
2 Megapixel
Lens Aperture
F/2.4
Lens Element Qty
3-element
Functions
Macro camera
3-piece lens
Third Camera
Sensor Resolution
2 Megapixel
Lens Aperture
F/2.4
Lens Element Qty
3-element
Functions
Depth camera
Display
LCD display
LCD
Diagonal Size
6.52"
Display Resolution
1600 x 720 pixels
Display Format
HD+
Pixel Density
269 ppi
Max Brightness
480 cd/m²
Refresh Rate
60 Hz
Contrast Ratio
1500:1
Connector Type
Micro-USB , Handset jack - mini-phone 3.5mm
4230 mAh
Protective cover, USB cable, power adapter, SIM card removal tool
