Onkyo TX-SR313 Silver
Quicklinx: 81JPWS00 Mfr#: TX-SR313-S
  • Dolby Digital
HDMI® Support for 3D, Audio Return Channel, DeepColor™, x.v.Color™, LipSync, Dolby® TrueHD, DTS-HD Master Audio™, DVD-Audio, Super Audio CD, Multichannel PCM, and CEC
Direct Digital Connection of iPod/iPhone via Front-Panel USB Port
Dolby® TrueHD, DTS-HD Master Audio™, Dolby® Digital Plus, DTS-HD High-Resolution Audio™ Decoding
WRAT (Wide Range Amplifier Technology)
Discrete Output Stage Circuitry
Overlaid On-Screen Display (OSD) via HDMI
AMPLIFIER FEATURES
100 W/Ch (6 O, 1 kHz, 1% THD, 1 Channel Driven, IEC)
H.C.P.S. (High Current Power Supply) Massive High Power Transformer
Optimum Gain Volume Circuitry
PLL (Phase Locked Loop) Jitter-Cleaning Circuit Technology for S/PDIF Audio
PROCESSING FEATURES
TI Burr-Brown 192 kHz/24-Bit DACs for All Channels
Advanced 32-Bit Processing DSP Chip
4 DSP Modes for Gaming: Rock, Sports, Action, and RPG (Role Playing Game)
Advanced Music Optimizer for Compressed Digital Music Files
Theater-Dimensional Virtual Surround Function
CinemaFILTER™
Direct Mode
Double Bass Function
Non-Scaling Configuration
A-Form Listening Mode Memory
CONNECTION FEATURES
4 HDMI Inputs and 1 Output
Mass Storage Class USB Memory Playback Capability
HDTV-Capable (720p/1080i) Component Video Switching (2 Inputs and 1 Output)
5 Composite Video Inputs (1 Front/4 Rear) and 2 Outputs
3 Digital Audio Inputs (2 Optical and 1 Coaxial)
6 Analog Audio Inputs (1 Front/5 Rear) and 1 Output
Subwoofer Pre-Out
Speaker A/B Terminals
Color-Coded Speaker Terminals
Headphone Jack
OTHER FEATURES
Crossover Adjustment (40/50/60/70/80/90/100/120/150/200 Hz)
A/V Sync Control (Up to 400 ms at 48 kHz)
Tone Control (Bass/Treble) for Front L/R Channels
3-Mode Display Dimmer (Normal/Dim/Dimmer)
RDS (PS/RT/PTY/TP) (European Model Only)
40 FM/AM Random Presets
RIHD (Remote Interactive over HDMI) for System Control
Compatible with RI (Remote Interactive) Dock for iPod/iPhone
Full-Function RI Remote Control
  • Audio return channel and 3D video via HDMI
    Four HDMI inputs on the TX-SR313 allow you to easily integrate high-definition devices such as Blu-ray players, cable/satellite tuners, and gaming consoles. HDMI implementation on this receiver also supports an audio return channel, allowing audio received directly by your TV's tuner to be sent "upstream" to the A/V receiver. That means you can enjoy television programs in magnificent Onkyo sound. HDMI also supports 3D video and numerous other high-resolution formats, and has the added advantage of reducing cable clutter for a cleaner and simpler install.
  • Direct digital iPod/iPhone connection for cleaner sound
    The receiver's front-panel USB port lets you play MP3 and AAC stored in an iPod/iPhone, and MP3, WMA, AAC, and FLAC audio files stored on a flash-memory device, using the system's own remote for track selection and playback. Your music will also sound much cleaner and clearer, as the audio signal is transported in digital rather than analog form through the direct digital connection.
  • Enjoy lossless high-definition movie soundtracks
    The TX-SR313 can decode Dolby TrueHD and DTS-HD Master Audio - two "lossless" Blu-ray formats that deliver a soundtrack identical to the studio master, so you're hearing it exactly as it's meant to be heard. The TX-SR313 also handles Dolby Digital Plus and DTS-HD High Resolution Audio. Dolby Digital Plus is designed to accompany HD video delivered via disc media, television broadcasts, and online content. DTS-HD high resolution audio, meanwhile, offers a higher bit and sampling rate than the core DTS technology.
  • WRAT (Wide Range Amplifier Technology)
    Gives even higher fidelity WRAT is a suite of powerful technologies Onkyo developed to improve signal-to-noise ratios, and enhance the fidelity of amplified audio. The technologies work to reduce noise across the frequency range, guaranteeing a well-balanced performance even with the most dynamic soundtracks. It achieves this by employing a low negative-feedback amplifier design; using "closed" ground-loop circuitry to cancel noise from individual circuits; and by ensuring high instantaneous current capability to cancel reflex energy and impedance fluctuations from the speakers. The WRAT design has helped make Onkyo AVRs the firm favorite among discerning audio enthusiasts, and is incorporated for the first time on the entry-level TX-SR313.
  • Discrete output stage circuitry boosts audio performance
    A receiver's ability to deliver high power into low impedances is a vital factor in its performance. If the current flow through the amplification circuit is inconsistent, audio quality will suffer. Rather than using inferior 'all-in-one' amplification chips, Onkyo receivers feature separate components at the signal output stage. Discrete transistors help guarantee a consistent, stable supply of current to the speaker system for an open and assured performance, with less chance of distortion and cooler running temperatures.
  • Convenient overlaid On-Screen Display via HDMI
    The TX-SR313's overlaid On-Screen Display (OSD) feature makes changing the settings on your A/V receiver quick and easy. On-screen set-up menus appear overlaid on the video image you're watching. This means you can adjust the settings immediately, without having to stop the program and switch to a different screen to access menus.
  • Get more realistic action with four gaming modes
    Select from four different optimized audio modes to match your gaming content for a highly realistic surround sound experience. Rock, sports, action, and RPG game modes will help to bring out the best in any soundtrack, from subtle ambient effects to thundering explosions.
  • Excellent-quality DACs deliver clearer sound
    Digital-to-analog converters are of particular importance to audio fans seeking excellent sound reproduction, and the TX-SR313 features reliable, high-performance 192 kHz/24-bit chips from Burr-Brown. As well as optimizing analog performance, these DACs are highly resistant to "clock jitter", a subtle form of digital distortion.
  • Advanced music optimizer to enhance compressed digital music files
    While MP3 or AAC files can sound fine through the headphones of your portable music player, the limitations of these files can be exposed when played back through a quality home entertainment system. This is because a significant amount of high-frequency bit information is lost during the file-compression process. To counter this, Onkyo has designed the advanced music optimizer to compensate for lost bit information and improve the quality of compressed audio signals. This results in a clearer and more expansive sound. Also included in this technology is a loudness correction feature that further improves the audio character of compressed files.
Onkyo TX-SR313 - AV receiver - 5.1 channel
AV receiver
Enclosure Colour
Silver
Audio Channels
Surround Sound
Audio Specifications
Amplifier - 5 - 100000 Hz - 100 dB
Decoders
Dolby Digital, Dolby Digital Plus, DSD decoder, Dolby TrueHD, DTS-HD Master Audio, DTS-HD High Resolution
HDMI Switching
Surround Sound Effects
Theatre-Dimensional Virtual Surround
Sound Effects
CinemaFILTER, DoubleBass
Surround System Class
5.1 channel
Frequency Response
5 - 100000 Hz
Radio System
Radio tuner - AM/FM - 40 preset stations
Remote Control
Universal remote control - infrared
43.5 cm x 31.8 cm x 15 cm
7.6 kg
AV receiver
Enclosure Colour
Silver
Audio System
Audio Channels
Surround Sound
Decoders
Functions
AV receiver
Audio D/A Converter
24bit / 192kHz
Sound Effects
Digital Sound Processor (DSP)
DSP Presets
Rock, Action, Sports, Role Playing Game (RPG)
5.1 channel
Amplifier - Response Bandwidth - 5 - 100000 Hz - SNR - 100 dB
Frequency Response
5 - 100000 Hz
Signal-To-Noise Ratio
100 dB
Input Impedance
47 kOhm
Input Sensitivity
200 mV
Total Harmonic Distortion
0.08%
Amplifier Output details
100 Watt - 6 Ohm - at 1 kHz - THD 1.0% - 5 channels (surround)
Bass Control
Treble Control
Display Dimmer
On-screen display, source direct, Wide Range Amplifier Technology (WRAT), Audio Return Channel (ARC), iPod/iPhone ready
Signal Processing Features
HDMI Switching
Connectors
Headphone Jack
Coaxial Digital Input
Optical Digital Input
Radio System
Radio tuner - AM/FM - digital radio tuner
Preset Station Qty
40 preset stations
Supported RDS Functions
TP, PTY, PS, RT
Remote Control
Connectors
Headphones (phone stereo 6.3 mm) - front , Composite video/audio input (RCA x 3) - front , SPDIF input (RCA) - rear , 2 x SPDIF input (TOS Link) - rear , Subwoofer output (RCA) - rear , 4 x composite video/audio input (RCA x 3) - rear , Audio line-in (RCA x 2) - rear , Composite video/audio output (RCA x 3) - rear , Monitor output (RCA) - rear , 2 x component video input (RCA x 3) - rear , Component video output (RCA x 3) - rear , 4 x HDMI input (19 pin HDMI Type A) - rear , HDMI output (19 pin HDMI Type A) - rear , Remote control - rear , USB (4 PIN USB Type A) - front
Power supply - internal
43.5 cm
31.8 cm
15 cm
7.6 kg
