5.1.2-Channel Dolby Atmos® Home Cinema Package
Movie Night Will Change Forever
- Supports Dolby Atmos® up to 5.1.2 Channels (Speakers Included)
- 100 W per Channel
- HDMI® 4 In / 1 Out (4K UltraHD / HDCP 2.2 / 4:4:4)
- Pure Driving Power from Discrete Amp Technology
- Bluetooth Wireless Audio Streaming
- Simple Rear Panel Layout for Easy Connection
What an awesome way to experience game-changing Dolby Atmos® sound! Everything you need to create a face-melting entertainment system is right here in one simple package, starting with a 100 W/Ch A/V receiver that connects all your media players and sends video to the TV via a single HDMI® cable—from your old analog game consoles to the latest 4K/60 Hz video with 4:4:4 color space and 21:9 cinema aspect. Want full Smart TV capabilities? Plug a media streaming stick into the rearside STRM Box port and enjoy a wealth of audio and video streaming apps. Once you’ve connected the speaker system—which allows multidimensional Atmos soundtracks to flow above and around you—AccuEQ optimizes the sound to suit the unique shape of your room. We’ve also included Bluetooth technology so you can hear streamed audio with Onkyo’s legendary clarity and dynamism. Unleash tomorrow’s entertainment at home today!
Extraordinary Dolby Atmos®
Dolby Atmos transports you into an extraordinary surround sound experience with captivating multidimensional sound objects that fill your room and flow all around you. This 7.1-channel receiver powers a 5.1.2-channel Dolby Atmos speaker setup: 5.1 standard surround configuration plus two height channels inside the front speakers.
Top Quality Speaker System
Onkyo knows a thing or two about building great speakers, having almost 70 years’ experience in Hi-Fi. The included speaker package features precision drivers housed in solid cabinets—the front speakers also housing up-firing height drivers that unlock the magic of Dolby Atmos.
HDMI® 4 In / 1 Out for UltraHD
All HDMI terminals support the latest TV video displays, and HDCP 2.2 copy protection encoded in content from movie studios, broadcasters, and streaming services, for next-generation UltraHD.
True Power from Discrete Amplifiers
Discrete amps deliver high instantaneous current to increase speaker control for accurate and dynamic audio reproduction. This precise power is the cornerstone of Onkyo’s amplification philosophy.
Bluetooth Audio Streaming
Stream virtually any audio from your smartphone, tablet, or PC to your home cinema for clear and powerful sound.
AccuEQ Room Acoustic Calibration
AccuEQ measures and corrects speaker distances, output levels, crossover frequencies, and frequency response from one quick and easy listening position to ensure clear and balanced surround-sound.
HDMI Video Up-Conversion
Only one wire! Every video signal is converted and sent to your TV through one HDMI cable.
Ready for Streaming Media Devices
The handy STRM Box port supplies power to streaming media players. Keep up with your video subscription services and other programs streamed from the Internet.
- Onkyo HT-S5805 - home theater system - 5.1.2 channel
- Product Type
- Home theater system
- Components
- AV receiver, speaker system
- Enclosure Colour
- Black
- Audio Channels
- Surround Sound
- Audio Specifications
- Amplifier - 10 - 100000 Hz - 100 dB 0.08%
- Decoders
- DTS-ES decoder, DTS 96/24, Dolby Digital, DTS decoder, DTS Express, Dolby Digital Plus, SBC decoder, DSD decoder, Dolby TrueHD, DTS-HD Master Audio, DTS-HD High Resolution, Dolby Atmos
- Surround Sound Effects
- Theatre-Dimensional Virtual Surround
- Sound Effects
- CinemaFILTER, Music Optimiser, Phase-Matching Bass Boost
- Surround System Class
- 5.1.2 channel
- Radio System
- AM/FM - 40 preset stations
- Speakers
- 2 x main channel speaker - external - 130 Watt - 55 - 50000 Hz , 1 x centre channel speaker - external - 130 Watt - 65 - 50000 Hz , 2 x surround channel speakers - external - 130 Watt - 80 - 20000 Hz , 1 x active subwoofer - external - 150 Watt - 27 - 150 Hz , 1 x height channel speaker - external - 130 Watt - 80 - 20000 Hz
- Power
- AC 230V (50/60 Hz)
- Product Type
- Enclosure Colour
- Black
Audio System
- Components
- Audio Channels
- Surround Sound
- Decoders
- Functions
- AV receiver
- Audio D/A Converter
- 24bit / 192kHz
- Sound Effects
- Digital Sound Processor (DSP)
- DSP Presets
- Rock, Action, Sports, Role Playing Game (RPG)
- 5.1.2 channel
- Amplifier - Response Bandwidth - 10 - 100000 Hz - SNR - 100 dB - THD - 0.08%
- Input Impedance
- 47 kOhm
- Input Sensitivity
- 200 mV
- Amplifier Output details
- 100 Watt - 6 Ohm - at 1 kHz - THD 1.0% - 7 channels (surround)
- Built-in clock
- Timer, sleep timer
- Bass Control
- Treble Control
- On-screen display, source direct, Wide Range Amplifier Technology (WRAT), Bluetooth Audio Streaming, Audio Return Channel (ARC), low-cut filter, AccuEQ room acoustic calibration
Speaker System
- Speakers
- 2 x main channel speaker - 2-way - external - 130 Watt - 55 - 50000 Hz - 6 Ohm - wired , 1 x centre channel speaker - 2-way - external - 130 Watt - 65 - 50000 Hz - 6 Ohm - wired , 2 x surround channel speakers - external - 130 Watt - 80 - 20000 Hz - 6 Ohm - wired , 1 x active subwoofer - external - 150 Watt - 27 - 150 Hz - wired , 1 x height channel speaker - external - 130 Watt - 80 - 20000 Hz - 6 Ohm - wired
- Driver Details
- Main channel speaker: 1 x woofer driver - 5" , Main channel speaker: 1 x tweeter driver - 1" - balanced dome , Height channel speaker: 1 x full-range driver - 3.25" , Centre channel speaker: 2 x woofer driver - 3.25" , Centre channel speaker: 1 x tweeter driver - 1" - balanced dome , Surround channel speaker: 1 x full-range driver - 3.25" , Active subwoofer: 1 x subwoofer driver - 8"
Radio System
- AM/FM - digital radio tuner
- Preset Station Qty
- Supported RDS Functions
- TP, PTY, PS, RT
- Connectors
- Headphones (phone stereo 6.3 mm) - front , Composite video/audio input (RCA x 3) - front , 4 x HDMI input (19 pin HDMI Type A) - rear , HDMI output (19 pin HDMI Type A) - rear , SPDIF input (RCA) - rear , 2 x SPDIF input (TOS Link) - rear , 6 x audio line-in (RCA x 2) - rear , 2 x component video input (RCA x 3) - rear , 2 x composite video input (RCA) - rear , Subwoofer output (RCA) - rear , 2 x front speakers output (banana/spade x 2) , 5 x speakers output (click-fit x 2) - rear , Remote control (mini-phone 3.5mm) - rear , FM antenna (IEC connector) - rear , AM antenna (click-fit x 2) - rear
- Included Accessories
- AM antenna, FM antenna, 2 AA batteries, auto calibration microphone, universal remote control
- Voltage Required
- 420 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Idle
- 55 Watt
- Dimensions (WxDxH) / Weight
- AV receiver: 43.5 cm x 32.8 cm x 16 cm / 8 kg , Speaker system: main channel speaker: 15.5 cm x 18.3 cm x 46.7 cm / 3.6 kg , Speaker system: centre channel speaker: 40.9 cm x 12.1 cm x 11.5 cm / 2.2 kg , Speaker system: surround channel speaker: 11.5 cm x 9.6 cm x 23 cm / 1 kg , Speaker system: active subwoofer: 23 cm x 41 cm x 42.5 cm / 7.7 kg
- Width (Shipping)
- 77.2 cm
- Depth (Shipping)
- 51.4 cm
- Height (Shipping)
- 85.5 cm
- Weight (Shipping)
- 34 kg
