OmniMount Wall Mount 20-40"
Quicklinx: 8NCFWS00 Mfr#: LED-W120
Hurry, only 1 left in stock!
£25.46 ex VAT
£30.55 inc VAT
The NewStar LED TV wall mount, model LED-W120, allows you to mount a LED TV to any wall. Cause of the flexible hole pattern of this system is this wall mount useable for almost every LED TV up to 40 inches. This wall mount is easily to install by using the VESA hole pattern at the rear side of your TV. This wall mount can be used when the maximum distance between the holes (left to right) is 20 cm. The upper and lower holes allow a maximum distance of 20 cm. This LED TV wall mount is made of aluminum and is mountable to any wall.
Neomounts LED-W120 bracket - fixed - for LCD display - black
Bracket (fixed) - wall-mountable
Adjustable Depth
1.7-3 cm
Recommended Use
LCD display
Recommended Display Size
22"-40"
VESA Mounting Interface
Up to 200 x 200 mm, from 100 x 100 mm
Max Load Weight
50 kg
5-year warranty
Adjustable Depth
1.7-3 cm
AV Furniture
Bracket
Design
Fixed
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
22"-40"
Max Load Weight
50 kg
Fixed
Limited warranty - 5 years
