Olympus WS-811 2Gb Digital Voice Recorder - Silver
Quicklinx: 82XFWS00 Mfr#: V406141SE000
  • microSD
  • microSDHC
  • MP3
Its design and engineering make the WS range a consummate blend of versatility and functionality, conceived to get the job done no matter whether you're working or playing. At a single glance, it already gets clear thumbs up - impressing with an ultra-slim body, lightweight build and super-stylish finish. But there is so much more hidden away inside: all WS recorders include music player, calendar search, scene select, index marks as well as the noise cancel feature and offer excellent high-sensitivity stereo sound quality for recording personal notes, meetings or conversations. The WS-811 as an entry-level WS recorder has an ample 2 GB memory plus an in-built microSD slot. It also has easily as much memory capacity as you will ever need plus a super handy integrated USB stick to keep life extra-easy.
Olympus WS-811 - voice recorder
Voice recorder flash based
Enclosure Colour
Silver
4 cm x 1.5 cm x 10 cm
Playback Digital Standards
WMA, MP3
Sound Output Mode
Stereo
Equaliser Factory Presets
Music, Voice
Digital Recording Time
32.5 hours - Stereo XHQ, 65.5 hours - STHQ (Stereo High Quality), 131 hours - HQ (High Quality), 258 hours - SP (Standard Play), 514 hours - LP (Long Play)
Display
LCD - 108 x 84 - monochrome - 1.43"
Audio Specifications
Digital Player - response bandwidth: 40 - 19000 Hz
Supported Flash Memory Cards
microSDHC, microSD
Internal Memory
2 GB
Speakers
1 x speaker - built-in - 80 mW
Microphone
Microphone - built-in - stereo
USB 2.0
1 x AAA type
Voice recorder
Digital Player Type
Flash based
USB Specification Version and Speeds
USB 2.0
Enclosure Colour
Silver
Enclosure Material
Plastic
Interface Supported
USB 2.0
Audio Formats
WMA, MP3
Audio System
microSDHC, microSD
Internal Memory
2 GB
File System Supported
2 GB
Sound Output Mode
Stereo
Functions
Digital player, digital voice recorder
Equaliser
Digital Player - response time: 40 - 19000 Hz
Hold button, noise cancelling circuit, voice activated, retractable USB connector
Display
LCD - monochrome
Display Illumination
Display Illumination Colour
White
Resolution
108 x 84
Diagonal Size
1.43"
Display Menu Language
Danish, Brazilian Portuguese, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
Equaliser
Music, Voice
Speaker System
Speakers
Driver Details
Speaker: 1 - 0.71"
Digital Player (Recorder)
Recording Time
Data Storage Capability
Up to 200 messages / 5 folders
Supported Bit Rate
8 - 320Kbps (MP3) / 5 - 320Kbps (WMA)
External Hard Drive Function
A-B repeat
Microphone
Microphone Operation Mode
Stereo
Connector Type
Microphone , Headphones , USB 2.0 (4 PIN USB Type A)
1 x AAA type
Included Qty
1
Battery Life Details
Digital recording - up to 27 hour(s) , Digital playback - up to 30 hour(s)
Microsoft Windows XP SP2 or later, Microsoft Windows Vista / 7, Apple MacOS X 10.4.11 - 10.7
4 cm
1.5 cm
10 cm
